Question about Garden
Shindaiwa t261 weed trimmer
Won't start. How is the proper way to choke it?
#1 Taper
  • 1040 Answers
SOURCE: Echo weed trimmer only run with choke half on
Check the fuel lines for breaks. When they get old, they become brittle.
If this doesn't work, you will need to clean the carburetor. Disassemble the carb. and spray with carb. cleaner. Use a Den Tek Brush,(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in the carb. Make sure the small screen is free of debris. Reassemble and start.
If neither one of these solutions work then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Posted on Jun 09, 2009
  • 218 Answers
SOURCE: I have a stihl fs76 weed trimmer. It will start
Hi..my name is Keith...it sounds like the reeds in your carb needs replacing...usually if you use a carberator cleaner on them..it will ruin them..plus age will make them stiff..they should be as soft a rose petal..and its cheap and inexpensive to replace..but you have to pay attention to how many layers and the shape of the reeds that come out..because the kit that you buy will fix several different carbs..i hope this has helped..if not..write back
Posted on Jul 01, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Posted on Jul 31, 2009
SOURCE: The trimmer starts like a dream but only runs with choke on
sounds like the carb needs to be removed and cleaned. It the chunk of metal that has the fuel line going to it on top of the engine.
Use a phillip screwdriver and possible a small ratchet to break it down and clean it thuroghly with gasoline.
After you get it back together and have cleaned it up as much as possible, crack her up with full choke again. this time though, allow it to run and barely ramp up the rpms enough to give it a little lug. When the engine seems to begin losing power, (these adjustments should be as small as possible until you get her running smooth) dial the choke back just enough to ramp up the rpms. This will probably take a few tries, but most definately should work in your case.
Once the trimmer is running smooth with the choke off you will be good to go.
Many times our trimmers and other 2cycle engines dont get the proper attention to keep them running up to par. Take the time to consider the unique properties of your tools to determine any possible future repair. Anytime you have and engine that burns a home mixed fuel there will be the risk of trash in the fuel system
GOOD LUCK AND PLS RATE THIS POST!!!! :D
Posted on Jun 03, 2010
hunter19_46m
  • 7482 Answers
SOURCE: have a troy built tb
Sounds like you will need to clean your carburetor. Sounds like you have gotten some trash in the cauburetor, check your fuel container to see if more trash is in it.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
I push primer on craftsman 32cc weed wacker trimmer and gas just runs out carb all lines are hooked up properly any suggestions
its supposed to,thats where the gas goes when you prime it,hold it up or choke it to start
Apr 17, 2015 | Craftsman Garden
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
Do you know what the proper Champion part number is for a Toro 51972 weed trimmer is? This was purchased used and it had a RCJ4 Champion plug in it and I just need to verify that this is the correct plug....
that is the correct spark plug for the unit. i work at a power equipment store where we work on homelites. 90% of the time it wont start or run right is usually carb issues . need to get it rebuild or replaced
Aug 25, 2011 | Toro& Electric String Trimmer
I have a ryobi weed wasp line trimmer, it's a few years old maybe 12 years, the other month I left the machine out in the rain over night, and now after numourus intermittent tries over severel weeks...
sounds like the carb is gummed up. take the carb off and take it apart. pull the needle out and make sure it slides freely, if that doesnt fix it there probabbly an air leak in one of the fuel lines or the prime ball.
Jul 09, 2011 | Refrigerators
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Shindaiwa model t25 weedeater won't keep running after fuel in squeeze buld has been exhausted
I had same problem, and changed diaphrams, but carb will not adjust or run without choke on. I am thinking control module. $55.95 or coil @ $51.00.
Jul 14, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
