Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525 3 fast red lights then 1 long repeating
When i 1st power it up i get flashing status light forever, so i unplugged it and held down the power button, after this i get a blinking red status light, 3 quick flashes then 1 long flash repeating endlessly, i cleaned the air vents and reconnected the lamp, with no effect..... ideas? i also have the mitubishi 52525 (52 inch model) are any of the parts interchangeable?
  • 1 more comment
  • billy mc Apr 29, 2013
    resolved reconnected all fans, and no longer getting the same error, now just seeing red lamp indicator light,
  • billy mc May 03, 2013
    i replaced the bulb and still get solid red lamp light, ..plz advise!
  • Anonymous May 07, 2013
    based on the symptoms youve got on this one, this tv requires to be checked by a servicer, it's giving us an error message which may indicated something internal's gone bad.
  • Mitsubishi Master
  • 3,459 Answers
Not sure if they can be swapped out....you may want to get the schematics or service manuals and check
Posted on Apr 30, 2013
5 Suggested Answers
SOURCE: mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Posted on Sep 17, 2008
  • 64 Answers
SOURCE: mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Posted on Aug 01, 2009
  • 171 Answers
SOURCE: A message flashes at the bottom of the screen
tv is overheating.  possible that fan not working or temperature protection circuit faulty.  check fan for excessive dirt first.  could be as simple as cleaning the fan
Posted on Jul 30, 2010
bugoy31
  • 1238 Answers
SOURCE: I have a Mitsubishi WD-62525 TV the lamp red light started to to flash red so i replaced the lamp did not fix the problem so i replaced the lamp ballast light is still flashing red...can someone pleas
please count the flashing led light on the front..
after you count click this link www.fixya.com/users/bugoy31
then choose any of my services to help you fix it..
Posted on Feb 04, 2012
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
We have a mitsubishi WD-62525 tv and we turned it on and after a while it turned itself off and then we got a continiously flashing red status light! what does this mean & what do we need to do to fix...
Mitsubishi 62525 power reset issue
The reason the light flashes, is because the tv is still on, that is the fan is cooling off the lamp. It will go off after about 1 minute. This is normal.
Jun 19, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Hello Need expert advice on the above problem - status light is constant red- we unplugged power and reset, tv green light comes on and then shuts off when red status light comes on. No picture at all. I...
The 18 code does not exist. To read the code press device/input button and menu button at the same time on the tv. count the LED flashes 1st digit short pause 2nd digit long pause, repeats.
The red status lamp indicates there is no communication between the format board and the DMD board (light engine). The most common problem for this is capacitors on the Format board that require hours of labor and possibly sending the entire electronics package to Mitsubishi if the caps don't do the trick. Expect a very large bill, contact you local Mitsubishi Authorized repair facility about this, DO NOT take a chance on your corner repair shop to know how to accomplish this.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
