Question about Genie Company Genie 27884W 4 Wire Wall Console
Geneie 27884W 4 wire wall console broke what can i use to replace
Don't have set up manuals for sega geneis
if it is a plug and play select av port channel 1. if it I s a regular system , put your tv on channel 3 or 4 to play games.
Oct 21, 2012 | Sega Genesis Console
After 12 months our new Whirlpool Cabrio washer shut down after start up with the F1 code, after installing the new circuit board for $300 , the glass top broke during a rinse cycle but did not come...
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cuts off on F1. have to rest several times
#1
#2
#3
#4
#5
#6
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%
May 05, 2010 | Whirlpool WTW6400SW Cabrio Washer
F1 error codecomes up on both the wash and rinse cycles. Repeatedly hittong cancel and start 4-5 times for each cycle clears it and the washer appears to wash the clothes. Would like to fix it though.
#1
#2
#3
#4
#5
#6
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Apr 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
It stops working and we get code F1.
#1
#2
#3
#4
#5
#6
Feb 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not begin cycle. F1 appears
#1
#2
#3
#4
#5
#6
Dec 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
When I first start a load I will get the f1 error and have to restart the load 3-4 times to get it to go. Then it always gets an f 1 error when it reaches 19 minutes left in the cycle. Any suggestions?
#1
#2
#3
#4
#5
#6
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$%
Nov 22, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I just replaced the controller today for the F1 code. Now the machine will not agitate in any settings, it fills the drum and then it drains it the wash timer jumps to about 4 minutes then it turns a few...
#1
#2
#3
#4
#5
#6
Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Iam getting the F1 alarm anytime a cycle starts,after I press pause & hit start 4 or 5 times it starts to work normal until it gets to the rinse & i have to hit start 4 or 5 times again.What part...
#1
#2
#3
#4
#5
#6
Oct 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Door wont open on Whirlpool washer cabrio display says du
To Access/replace the switch:
#1
#2
#3
#4
#5
#6
Jan 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Genie Company Genie 27884W 4 Wire Wall Console Logo
130 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
