Question about Mtd Garden
Removing blower housing
Idles fast
  • 31 Answers
Loosen the bracket on the engine holding the throttle cable start it and move the cable until it idles right but first check the idle screw on the carb turn to the leftwhile running
Posted on Jan 27, 2014
I need to find timing marks for 1984ford 6.9diesel
To ,set the static timing on your 6.9.
1. Remove the fast idle bracket and solenoid from the pump.
2.Slightly loosen the 3 nuts that hold the pump to the engine.
3.Turn the pump until the timing mark on the pump mounting flange aligns with the mark on the pump gear housing, within .030 inch.
4. Remove the tool and tighten pump mounting nuts securly and re-check the timing marks.
5. Reinstall the fast idle bracket and solenoid.
Once this is done, it will have to go to a diesel repair shop to be "dynamic timed". This pinpoints the timing exactly but must be done with very specialized tools.
Oct 25, 2014 | Cars & Trucks
Poulan snow blower will not idle down engen running to fast
usually when a 2 cycle won't idle down and runs too fast it's a sign of vacumn leak (sucking Air) into the crankcase,at crank seals
Dec 04, 2011 | Garden
How to replace heat blower
NOTE: The blower motor is located on the passenger side of the vehicle under the instrument panel. The blower motor can be removed from the vehicle without having to remove the HVAC housing.
  1. Disconnect and isolate the negative battery cable.
  2. Remove the passenger side cowl trim panel. See: Body and Frame\Interior Moulding / Trim\Trim Panel\Service and Repair\Cowl Trim
  3. Pull back the carpet to access the front upper screw that secures the air inlet housing.
  4. Remove the recirculation door actuator.
  5. Remove the recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside.
  6. Disconnect the blower motor wire lead connector from the blower motor resistor or power module, depending on application.
118348823 Lower Air Inlet Housing
  1. Remove the one screw (from the top) that secures the lower air inlet housing to the upper air inlet housing.
  2. Remove the four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing.
118348824 Blower Motor Wire Lead Grommet
  1. Push the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  2. Feed the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  3. Position the recirculation-air door as necessary to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  4. Gently flex the recirculation air door far down enough to remove the blower motor and wheel from the HVAC housing.
118348825 Blower Motor Mounting Tabs
  1. Remove the blower motor and wheel from the HVAC housing. Note the position of the blower motor mounting tabs.
INSTALLATION
Nov 28, 2011 | Chrysler Sebring Cars & Trucks
How to remove and install a new heater blower motor 2000 Saturn
Removal & Installation
  1. Select the following settings:
    Turn the ignition ON Select Recirc in the OFF setting Turn the ignition OFF
  2. Disconnect the negative battery cable.
  3. Remove the wiper arm assemblies.
    CAUTION A sharp edge is revealed once the weatherstrip is removed.
  4. Remove the weatherstrip at rear of the engine compartment.
  5. Remove the cowl retaining nuts.
    Fig. Remove the cowl screen assembly
  6. Remove the cowl screen assembly.
  7. Rotate the locking tabs outward to release the filter assembly.
  8. Remove the filter by lifting straight up.
    Fig. Remove the wiper module retaining bolts
  9. Remove the wiper module retaining bolts.
  10. Reposition the wiper module to the right.
  11. Remove the filter housing attachment bolts.
  12. Remove the filter housing.
  13. Remove the blower motor housing:
  14. Remove the blower motor housing screws
    Fig. Release the locking tabs and remove the fan housing
  15. Release the locking tabs and remove the fan housing
  16. Disconnect the blower motor electrical connector.
  17. Squeeze the bottom of the connector and pull downward.
  18. Remove the blower motor assembly by lifting straight out.
To install:
NOTE The fan motor assembly rib must be located into the channel in the module housing.
  1. Install the blower motor assembly into the module housing.
  2. Connect the blower motor electrical connector.
    NOTE The housing rib must fit into the slot in the HVAC module case.
  3. Install the blower motor housing. Snap the left and right clip into place
  4. Tighten the fan housing to blower motor housing screws to 9 inch lbs.(1 Nm).
    NOTE A new filter housing seal must be used whenever the filter housing is removed to prevent water from leaking into module.
  5. Remove the filter housing seal using a small flat-blade screwdriver.
  6. Install a new filter housing seal.
  7. Install the filter housing.
  8. Install the filter housing screws, and tighten the screws to 31 inch lbs.(3.5 Nm).
  9. Position the wiper module.
  10. Install the wiper module bolts, and tighten the bolts to 44 inch lbs.(5 Nm).
  11. Install the passenger compartment air filter. Notice the air flow direction indicator printed on side of the filter.
  12. Rotate the locking tabs on the filter housing inward to secure the air filter in place.
  13. Install the cowl screen.
  14. Install the cowl screen nuts, and tighten the nuts to 9 inch lbs.(1 Nm).
  15. Close filter access door.
  16. Install the weatherstrip at rear of the engine compartment.
  17. Install the wiper arm assemblies.
  18. Connect the negative battery cable.
  1. Disconnect the blower motor electrical connector.
  2. Remove the lower blower motor cover retaining screws.
    Fig. Remove the lower blower motor cover
  3. Remove the lower blower motor cover.
  4. Remove the blower motor nuts.
    NOTE Cut through the case as straight as possible because the motor cup must be replaced.
  5. In order to prevent damage to the component, do not cut any deeper than necessary to remove the motor cup.
  6. Remove the blower motor and cup from the lower case by cutting through the case between the circular ribs around the motor with a sharp utility knife.
  7. Release the blower motor retaining tab and remove the motor from the cup.
To install:
  1. Install the blower motor into the motor cup that was cut out of the lower case.
    Fig. Install the blower motor (1) into the motor cup (2) that was cut out of the lower case
  2. Install the blower motor nuts, and tighten the nuts to 21 inch lbs.(2.4 Nm).
  3. Attach the service ring to the motor cup with the screws included in the kit, and tighten the screws to 15 inch lbs.(1.8 Nm).
  4. Install the blower motor and service ring into the HVAC module using the screws included in the kit. Make certain the blower motor electrical connector is pointing rearward in the vehicle, and tighten the screws to 15 inch lbs.(1.8 Nm).
  5. Install the lower blower motor cover.
  6. Install the lower blower motor cover retaining screws, and tighten the screws to 15 inch lbs.(1.8 Nm).
  7. Connect the blower motor electrical connector.
Hope this helps (remember to rate and comment this).
Oct 04, 2010 | 2000 Saturn Ls 4dr Sedan
Where is the blower motor... i know that is the problem, but where and how do I change it. i already have the part
Blower Motor Removal & Installation Front To Remove:
NOTE: The blower motor is positioned on the passenger side of the vehicle beneath the instrument panel, and can be removed from the vehicle without removing the HVAC housing.
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Passenger side cowl trim panel
    • Carpet to access the front upper screw that secures the air inlet housing
    • Recirculation door actuator
    • Recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside
    • Blower motor wire lead connector from the blower motor resistor or power module, depending on application. Lower Air Inlet Housing chr_pacific_lwr_inlt_hsng.gif
    • One screw (from the top) that secures the lower air inlet housing to the upper air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing Blower Motor Wire Lead Grommet chr_pacific_blwr_wrg_grmmt.gif
  3. Feed the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  4. Push the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  5. Place the recirculation-air door as needed to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  6. Lightly bend the recirculation air door far enough down to remove the blower motor and wheel from the HVAC housing. Blower Motor Mounting Tabs blwr_mnting_tabs.gif
  7. Remove the blower motor and wheel from the HVAC housing. Make a note of the location of the blower motor mounting tabs.
To Install:
  1. Install or connect the following:
    • Blower motor and wheel to the lower half of the HVAC housing and line up the blower motor mounting tabs to the correct location on the HVAC housing
    • Blower motor and wheel into the HVAC housing by lightly bending the recirculation-air door far enough down
    • Three screws that secure the blower motor to the HVAC housing by positioning the recirculation-air door as needed
      1. Torque to: 17 inch lbs. (2 Nm)
    • Blower motor wire lead through the opening in the lower air inlet housing and seat the rubber grommet into the lower air inlet housing
    • Recirculation-air door pivot into the lower air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and the lower HVAC housing
    • Blower motor wire lead connector to the blower motor resistor or power module, depending on application
    • Recirculation door actuator wire lead into the routing clip located on the lower air inlet housing
    • Carpet
  2. Perform the heater-A/C control calibration procedure.
Rear To Remove:
NOTE: The rear blower motor and blower wheels are repaired only as a balanced unit. The entire blower motor and wheel assembly must be replaced if either component is fault or damaged.
    • Front center floor console cover
    • Negative battery cable Rear Blower Motor Housing chr_pacific_rear_blwr_hsng.gif
    • Body wire harness connectors from the rear blower motor power module and the rear mode door actuator
    • Body wire harness bracket from the console support bracket
    • Eight screws and the two console support brackets from the floor console base and duct assembly
    • Four screws that secure the rear blower motor housing to the floor console base and duct assembly
    • Rear blower motor housing and place it on a bench
    • Rear blower motor wire harness connector from the power module
    • Eleven retaining clips and three screws that secure the housing together
    • Two halves of the housing
    • Blower motor wire harness and grommet from the housing and remove the blower motor
To Install:
    • Rear blower motor into the housing and install the blower motor wire harness and grommet
    • Two halves of the rear blower motor housing and install the eleven retaining clips and three screws
    • Rear blower motor wire harness connector to the rear blower motor power module
    • Rear blower motor housing into the floor console
      2. Two console support brackets onto the floor console base
      3. Eight screws that secure the support brackets to the floor console base
      4. Body wire harness bracket onto the console rear support bracket
      5. Body wire harness connectors to the rear blower motor power module and the rear mode door actuator
      6. Negative battery cable
      7. Front center floor console
  2. Calibrate the A/C-heater control.
Aug 13, 2010 | 2004 Chrysler Pacifica
Engine stalls
I'd say the carb is clogged somewhere, probably the main jet. The gas today is terrible. Removal/replacement may be the (only) way to go.
May 25, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I need to replace a heater blower motor on a 2004 chrysler pacifica and picture schematics etc;
INSTALLATION
  1. Position the blower motor and wheel to the lower half of the HVAC housing. Align the blower motor mounting tabs to the correct location on the HVAC housing.
  2. Gently flex the recirculation-air door far down enough to install the blower motor and
Dec 02, 2009 | 2004 Chrysler Pacifica
2005 Town Country front blower motor inop fuse/relay ok
Break Down And Replace The Blower Motor
REMOVAL
WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS, DISABLE THE AIRBAG SYSTEM BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE. DISCONNECT AND ISOLATE THE BATTERY NEGATIVE (GROUND) CABLE, THEN WAIT TWO MINUTES FOR THE AIRBAG SYSTEM CAPACITOR TO DISCHARGE BEFORE PERFORMING FURTHER DIAGNOSIS OR SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIR-BAG SYSTEM. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN AN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY OR DEATH OR DEATH.
  3. Position the carpet to access the front upper screw that secures the air inlet housing.
  5. Disconnect the blower motor wire lead connector from the blower motor resistor or power module, depending on application.
    3. Push the rubber grommet through the opening in the lower air inlet housing.
    4. Route the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
    5. Position the recirculation-air door as necessary to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
    6. Gently flex the recirculation air door downward to gain access to remove the blower motor from the HVAC housing. NOTE: To aid in installation, note the position of the blower motor mounting tabs prior to removal
      1. Remove the blower motor from the HVAC housing by rotating and tilting the blower motor as necessary.
      INSTALLATION
      1. Gently flex the recirculation-air door downward to gain access to install the blower motor into the HVAC housing.
      2. Position the blower motor to the HVAC housing and tilt and rotate the blower motor as necessary to install it into the HVAC housing.
      3. Align the blower motor mounting tabs to the locations noted during removal and install the three screws that secure the blower motor to the HVAC housing. Tighten the screws to 2 N·m (17 in. lbs.).
      4. Route the blower motor wire lead through the opening in the lower air inlet housing and seat the rubber grommet.
      5. Position the recirculation door pivot shaft into the lower air inlet housing and install the inlet housing.
      6. Install the four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and the lower HVAC housing. Tighten the screws to 2 N·m (17 in. lbs.).
      7. Install the one screw (from the top) that secures the lower air inlet housing to the upper air inlet housing. Tighten the screw to 2 N·m (17 in. lbs.).
      8. Connect the blower motor wire lead connector to the blower motor resistor or power module, depending on application.
      9. Install the recirculation door actuator.
      10. Reposition the carpet.
      11. Install the passenger side cowl trim panel.
      12. Reconnect the negative battery cable.
      13. Perform the heater-A/C control calibration procedure.
Feb 07, 2009 | 2000 Chrysler Town & Country
Cold start/fast idle problem 190e petrol
Try online for a used unit or autohausaz.com or buymbparts.com to get parts.
Dec 16, 2008 | 1991 Mercedes-Benz 190
Garden Logo
26 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
