Question about Garden
Craftsman yt 3500 22hp
I just bought a new craftsman yt 3500 lawn tractor. The transmission will not engage. The forward/reverse pedal does no spring back into position after you take our foot off it.
  • 109 Answers
SOURCE: Hydrostatic Transmission Failure
There is a transmission bypass lever on the back of the mower, if the bypass is moved out of the drive position, it will not drive in either direction, and will be really easy to push.
Posted on May 03, 2009
  • 479 Answers
SOURCE: John Deere LT190 Lawn Tractor transmission problem
try to service the old transmisson it may work.but if that does not work just replace the transmisson.
purchasing a new hydrostatic transmission is much advisable as its definately the problem of hydrostatic transmission with out any doubt .but i hope servicing the old works.
Posted on Oct 01, 2008
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
  • 40 Answers
SOURCE: No forward progress
Seems that your clutch needs adjustment, no biggie here. Get your needle nose pliers and a spare ¼ inch bolt or pin. A small Philips screwdriver will also work. The needle nose pliers are for removing the cotter pin and the screwdriver (or bolt) will hold the brake lever in place while you make the adjustment. Then, check under the right side of the deck (side where the grass discharges) right under the plastic mat where your foot rests and next to the tractor's frame you will see the brake lever with the long spring attached. Have a helper move the brake/clutch pedal so you have a better idea of what's going on down there. Then:
1. Remove the cotter pin, washer, and brake spring from the
adjustable nut
2. Disconnect the adjustable nut from the brake lever assembly
and the parking brake latch.
3. Align the hole in the brake lever with the hole in the frame. Hold
the brake lever in place with your 1/4 inch pin, bolt or the screwdriver.
4. Pull the clutch rod forward until tight. Turn the adjustable nut
until the nut will fit through the hole in the brake lever.
5. Assemble the adjustable nut to the parking brake latch,
brake lever and brake spring. Fasten with the washer and
cotter pin.
6. Remove the 1/4 inch (6 mm) pin, bolt or scredriver.
That should return everything to normal. Assuming that there are no broken or bent parts in your clutch mechanism.
These are the general instructions for this type o tractor. If you find any discrepancies in the description of parts or location of mechanisms, please consult the owner's manual of your particular model under “How to check and adjust the clutch”.
I hope you find this solution helpful. Please rate it and thanks for using Fixya.
Posted on Nov 05, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
How to fix my craftsman riding mower, whcih dies after engaging blade
make sure blades not jammed. with mower off, try turning blades by hand.
it could either be a safety switch in the seat or for the reverse paddle.
make sure its not in reverse when you attempt to engage blades.
you should be able to bypass both switches with a jumper wire for testing purposes. if it works with jumper, replace the switch(s).
Sep 01, 2014 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Www managemyhome com
bad safty switch or shorting pto if pto replace it but i think one of your safty switches is bad
Aug 26, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
Yt 3000 42" will not move forward or backward
Your drive belt might be off or broken (upper one) not the belt that controls the blades. There's a rod at the rear of the mower that also controls the trans-axle, if it's pulled out, the transmission is disengaged. To purge air out of the system, you pull the rod out, keep it in the out position with a pin and move the motion lever to go forward and return it to neutral several times, then do the same thing to the reverse direction. Then release the rod and return it to the very most inner position. GOOD LUCK, hope it's not a bad transaxle.
Feb 24, 2014 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Transmission will not engage.
The transmission belt is probably loose or the clutch is faulty.
Apr 29, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 2008 Troy Bilt Pony lawn tractor will not engage in iether forward or reverse. No clear reason just stopped working. The transmission locks up and the tract or will not start either (probably because it...
Make sure the brake pedal is fully depressing. Check the linkages for the forward / reverse and brake pedal. Check for grass build up causing the linkages to bind.
Nov 26, 2017 | Garden
Mar 30, 2009 | Craftsman Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
752 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
