Question about Exercise & Fitness
E6 message Power lx1 treadmill.
I dont have the manual. and I think the incline needs to be recalibrated. can some advise for this brand
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: My Proform treadmill will not incline. It is stuck
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
Posted on Jun 24, 2009
  • 103 Answers
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ swflafitnessrepair@yahoo.com I will send this to you.
Posted on Nov 13, 2009
  • 103 Answers
SOURCE: Image 17.0 treadmill is stuck in incline position
Hello there, The first thing I would try is to calibrate the incline on the unit.
Do this using the following procedure.
With the safety key out, press the stop button along with the speed up button while inserting the safety key onto the unit.
remove your fingers from all buttons, Then press the stop button one time. Now press the incline up button one time.
The unit should go all the way to the top, then return to the bottom.
Remove the safety key and reinsert it to continue using the machine
If this does not work you can manually move the machine to the bottom using this procedure.
Remove the hood cover b removing 2 screws in the rear of the machine and removing the first 2 screws on the foot rails on each side.
You can now lift the cover out of the way.
At this point you will see the incline motor located in the center of the unit pointing in a downward direction.
On the top of the motor there will be a small fan encased inside of a metal cover. There will be a flat head screw located inside the metal frame where the fan is. Rotate this clockwise to lower the unit. (the motor is geared very high it may not seem as though it is moving but it is) be patient that procedure does take a little while.
Any questions please feel free to leave another message on this link.
Good Luck! Tim
Posted on Jan 12, 2010
SOURCE: Brand new Sole F85 incline shows e2 and stops
Same thing happens to me. Any solutions?
Posted on Dec 04, 2010
How do I clear the E6 code in a Xterra 3.0 treadmill?
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
Also note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service.
Apr 05, 2017 | Exercise & Fitness
Proform 1450 treadmill incline problems
try to calibrate incline. For that check the video
https://www.youtube.com/watch?v=uz1cMWei7AQ
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 12, 2016 | Proform Pro-Form Performance 1450
E6 error message
It appears that your elevation system is where the fault lies. This could be as simple as recalibrating the lift mechanism, or possibly correcting faulty wiring from the lower controller to the lift motor. Be sure to check the condition of the lift motor as well as the wires entering the lift motor. Sometimes the wires will pull away from the plastic connector causing a lift motor error
Mar 11, 2014 | Dmm Vision Fitness T9500 Treadmill
C2250 treadmill incline recalibration - incline goes up, not down
Plug the power out and plug it back in after a count of 50 could be that it needs to be reset .then plug back in the power and see what its doing if no luck go to manual and look for reset
Jan 06, 2014 | Nordic Track Exercise & Fitness
The incline is stuck in the highest position
Try recalibrate. If that dont work, replace the incline motor.
  1. Press speed^ and stop simultaneously
  2. Insert key
  3. Press stop once
  4. Press Incline up
  5. (This should recalibrate incline). If this fails, replace the incline motor.
Dec 31, 2013 | Proform Perspective Es Treadmill PFTL99806
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
Hello, WE have the model 4100i treadmill and the elevation is stuck in the highest position and won't reset to zero. How do I fix this or who can I call for this repair? Thanks, Tom
Try the calibration procedure found in the troubleshooting section of your manual first. Here are the basic instructions.
With the key in the console, press one of the Incline buttons. While the incline is changing (or the numbers on the console) , remove the key. After a few seconds, re-insert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. This will recalibrate the incline.
If it still doesn't move, remove the cover. Find the incline motor. You will see a slot in the end of the motor. Using a drill with a standard slotted screwdriver bit, spin the motor counterclockwise (if it is having difficulties spinning, turn clockwise instead) for just a couple seconds. Now do the calibration procedure again.
I have had machines that got stuck before. Once released and recalibrated, the operation was OK.
The service number for your machine is found on the model number sticker on the frame of the treadmill.
Feb 26, 2011 | Nordic Track Nordictrack Apex 4100i...
I have an Insight DK614 Tredmill that will not run. It displays an error message "E6" and the running deck will not lower. The motor is still running albeit at a much lower rate. No movement...
E6 or E7 An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait for 5-seconds and turn back ON.
Also, note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service. Treadmill Error Codes Troubleshooting
Oct 26, 2017 | Exercise & Fitness
Exercise & Fitness Logo
98 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
