I have a 46 inch Panasonic plasma a.HDTV I shipped it on a airplane got home the inside glass was cracked only got 2 weeks of use before i put it in storage every TV repair man tells me its gonna cost more and just to buy a new TV best but told me over a 1000$ can anybody help me
    New Friend:
    Problem Solver:
  • 15 Answers
If your talking about the front plate go to E-BAY, If all else works and put this in >
Samsung LN26A450 LN26A450C1DXZA /front plate glass
I seen a couple there for $35.00 and installation at local TV repair shop will be cheap less then $100.00 but most wont cover warranty on glass only workmanship. good luck!
Posted on Apr 29, 2013
tvtechnician
  • 105 Answers
SOURCE: Cracked glass on front glass
if the tv turn on this will tell you that the plasma panel itself is ok. if it is ok then the fron glass is replacable. this is just a standard piece of glass so i really wouldnt spend tons of money hiring someone else to order one and install it.
Posted on Nov 07, 2007
  • 52 Answers
SOURCE: Broken screen
if it is limited to external glass the glass can be ordered separately but if there is internal crack on pdp itself would have to replace pdp. from my experience generally if it limited to crack on external glass there still should be picture so there may be additional damage to plasma display itself
Posted on Aug 17, 2008
SOURCE: Flat panel tv repair
I have the same problem with a 52" inch XBR. Went to sony and have a extended warranty. Warranty doesn't cover physical or accidental damage. To replace the panel costs more than buying a new TV. This is not fair to consumer. The warranty I paid for is useless and I can't even get it repaired. There should be some kind of group action to resolve this issue.
Posted on Nov 22, 2008
  • 4 Answers
SOURCE: Samsung LN26A450 LN26A450C1DXZA won't turn on
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Posted on Oct 30, 2009
  • 4234 Answers
SOURCE: Cracked on Inside glass on 42in Plasma-Panasonic
This sounds like the panel itself is cracked. If this is the case, the set wil not completely power up as youi have seen. The panel can not be repaired as such, it must be replaced. I can rpovide you with the part number and cost if you can post the model number. Be aware however, that the cost of the panel may come close to the cost of a replacement set.
Dan
Posted on Dec 10, 2009
Testimonial: "Model # TH-42PX80U"
I have a Samsung plasma pn51e550d1f the screen has badly cracked, what is the cost of repair. ,eager to know please anyone? Thanks
Here is an example cost for a Panasonic 50 inch plasma.
$ 2915.00 Plasma screen only - does not include labor to install.
$ 248.00 Maximum shipping cost to deliver it to your home.
$ 3163.00 Total cost - Does not include labor to install.
Probably cheaper to buy a brand new TV.
Aug 17, 2015 | Samsung Televison & Video
Can I change the y sus board on my panasonic 46 inch plasma vieara
Actually this is a very skilled work. Anyway just check this link and see whether you can do it by yourself or not. It has detailed descriptions with illustration.
Jan 09, 2013 | Panasonic TCP46S1 46 HDTV Plasma TV
I have a 50 inch Pioneer Elite PRO and one of children threw the remote, hit the screen and cracked it. It looks like it is cracked inside (beneath the first layer of glass) The outer sheet of glass is...
My understanding is if any air gets in this area where the glasses are it will not work. You better ask a tv repair man to see if it is worth putting the money in to repair. There should be no charge unless you have him do something to it.
Sep 30, 2017 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Broken screen
Aug 16, 2008 | Philips BDS 4611 46 in. Plasma Television
Panasonic th-50px60u
If the glass that you can feel on the front of the tv is cracked, then just replace the glass (called filter). The cost is about 150.00. If the pannel is cracked buy a new tv. It costs to much.
Nov 26, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Nov 05, 2007 | Televison & Video
Broken Screen on Plasma TV
samsung 37 inch plasma screen cracked by my grandson. Can it be fixed
Jan 13, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
