Question about Stihl Garden
Stihl vent i have a stihl chain saw it will start but will not idle . i can take the breather off the end of of the vent tube and it runs fine except it is spitting fuel out of the vent tube .the vent tube i'm referring to is the one coming out of the tank not the one on at the cylinder head
  • Stihl Master
  • 1,807 Answers
Try replacing the tank vent, The vent acts as a 1 way valve allowing air into the tank to balance the atmos pressure. Does the carb also have a primer pump on it.? Sometimes faulty primer pumps can cause the tank to pressurise. You haven't stated the model otherwise i could have been a bit more accurate with the diagnosis. :)
Posted on Apr 29, 2013
SOURCE: Replacing the fuel vent hose on a Stihl chain saw
If it's the clear vent hose that connects to the tank on the left side, that's it. There is a brass plug inside the hose that meters outside air in the tank to regulate the pressure. The hose connects to the tank nipple, done.
Posted on Oct 17, 2011
  • 211 Answers
SOURCE: Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Posted on Feb 14, 2009
  • 42 Answers
SOURCE: new Stihl ms 180 idles but will not accelerate
sounds like you may have a broken throttle cable. take the top cover off and inspect to see if this is the problem. let me know if this is it or if you need more assistance with this.
Posted on Mar 08, 2009
  • 205 Answers
SOURCE: Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Posted on Mar 26, 2009
Dolfoff
  • 148 Answers
SOURCE: stihl 048 tank vent tube???? why does it have
the set screws restrict fuel flow out of the vent while allowing air to enter the tank
Posted on Sep 26, 2009
Adjust idle on stihl chain saw
adjust it at the throttle end on the carby
if you have the correct tool you can adjust the idle mixture as well
Sep 22, 2017 | Stihl Garden
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Is the LA adjuster for oiler to chain& what 1/4 turn per run to check ratio??
PDF]STIHL MS 261/261 C Chain Saw Instruction Manual ' STIHL ...
www.stihlusa.com/.../ms-261-261c-chain-saw-instruction-manual.pd...
Stihlde la rueda dentada usada y de otros ... this manual to operate your chain saw. ..... 1/4 turn). Misaligned, damaged or broken cap. N. If the cap does not drop fully .... adjust the chain while the engine is running! Warning! To reduce the risk of fire ...... bolts and screws except the carburetor adjustment screws after each use.
[PDF]STIHL MS 200 T Arborist Chain Saw Instruction Manual ...
Dec 15, 2015 | Stihl Garden
My chain saw starts but won't keep running what is wrong with it
Sparkplug ,If not. Try saw on half Choke, if works check filter in tank.
Jan 22, 2015 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Woodboss 028av. I removes the air filter. on the left side there is a tiny plastic tube with a tiny spring inside it. what is this for
I think you are looking at the fuel tank breather pipe. The AV just means; anti vibration. My Stihl parts list shows it as 1117 350 5800 Tank vent.(Plastic Tube) And 1120 358 8105 Vent Insert. Its basically a small plastic tube with a restrictor in it that vents the tank. Only repair it if there is gas leaking. A local shop would help or go online.
Nov 03, 2014 | Garden
Gas spraying out when trying to start
These saws have a vent tube located under the rear cover. If its missing, it will splash out when you try to start it. George
Mar 03, 2013 | Stihl Chain Saw Handle Models 044 046...
I have a ms290 starts fine idles fine but after about 15 minutes of cutting wood it loses power an dawgs out somtimes kills,
Hi goincrazy, check that your carb tubes are ok, and your exhaust filter is clean, also clean your fuel filter or get a new one. Hope that helps
Steve
Nov 09, 2011 | Stihl MS 290 Chain Saw include 20" 50cm...
Will start but will not stay running
The 455 was very prone to blocking the fuel tank vent, as a test, when the saw starts to die release the fuel cap, if the saw picks back up and runs normally it is a breather issue, the breather is pressed into the crankcase under the starter cover.
Feb 26, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
New Stihl ms 180 idles but will not accelerate
Mar 01, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Feb 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
509 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
