Question about Vehicle Parts & Accessories
Help 2004 stratus
I'm trying to switch out fuse box 2004 dodge stratus need to know where some wires go
    New Friend:
Plise my help mohan ph.9981051025
Posted on Apr 29, 2013
I have a 2004 dodge stratus and I'm trying to find
Technically, the starter is grounded to the engine block. There may be a ground strap that goes from the block to the body, but usually the battery ground cable goes to the block.
May 30, 2013 | Cars & Trucks
Have a 2004 Dodge Stratus 2.7 just replaced the starter with a new one and still wont start. All the lights and everything lights up on dash but the Car wont crank up! All wires are hooked up to the...
I'm guessing that it isn't even turning over. There are a couple of things you can check. Both are in the power distribution box under the hood of the vehicle (see picture below). Also below is a picture of the fuse and relay layout. There is one fuse directly related to the starter relay (number 8 marked with a red arrow) and also the starter relay itself (also marked with a red arrow). I hope this helps.
Nov 14, 2011 | 2004 Dodge Stratus
Fuel pump location dodge stratus 2004 also is there a reset switch?
Fuel pump in the gas tank....relay under hood in junction box..
Jun 04, 2011 | 2004 Dodge Stratus
I have a 2003 dodge stratus and all the lights work but the car wont crank over. I BANGED ON THE STARTER ALSO JUST NO CTANK
Check fuses, look at engine compartment fuse box, finda ASD relay swap it with horn relay. Try starting in neutral with foot on brake pedal(neutral saftey switch maybe bad). Check power at starter big wire(Need 12v+) check small wire while someone cranks car for you, you need a 12v+ while cranking, then it will go dead while not cranking. Cycle key-fob lock unlock, manually lock unlock driver's door(anti-theft problem). Check for faulty after market alarm system. (disabling starter).
May 17, 2011 | 2003 Dodge Stratus
My 2004 Dodge Stratus a/c blows air from the front window defogger vents, not from the ac vents, causing the window to fog up. It switches intermittently from each sometimes, too.
It sounds like you blew your 'hvac' fuse which should be located under the dash on the drivers side, just pull the cover off the fuse panel and on the backside of the cover it should say which fuse is which and when you pull out the fuse if you look at the side of the fuse there is a metal wire that runs through the fuse and if that wire is burnt then the fuse is bad. And if the fuse is not there then it is in the instrument/fuse panel under the hood. hopefully this works for you
Apr 29, 2011 | 2004 Dodge Stratus
I have a 2004 dodge stratus that has power to lights but does not turn over when i try to crank even after jumping it off.
Hi.
Check ignition switch fuse. This is a 20 Amps. see that it has not blown. In 2004 Fuse should be nr 8 in the power box under the hood (newer models #24).
Once you are sure that battery, fuse and wires are OK, check starter and ignition switch. Check if there is 12V to starter while cranking. If there is power and the starter motor does not turn, then the motor is gone.
If there is no power to starter motor when you crank, then the ignition switch located inside the steering column may need replacement. Before repairing, try reading error codes with a code scanner.
Apr 15, 2011 | 2004 Dodge Stratus
I need to find out which of my wires to my iac sensor are hot. do u hav a diagram? 2004 dodge stratus 3.0 liter
I found one in the Haynes Book but wiring is complicated to me. Try google iac hot wire color for 04 dodge stratus 3.0, it should tell you the color. Sorry, thats all I know to do.
Jan 10, 2011 | 2004 Dodge Stratus
97 Dodge Stratus cigarette lighter fuse. Which one is it?
it usually runs on the same fuse as the radio & interior light which is the accessories fuse, if these two things still work you may have another problem with the wiring,you might need to pull the lighter out & check the wiring.....hope this helps.....cheers
Jul 28, 2010 | 1997 Dodge Stratus
04 dodge stratus
Hi everyone I am going to answer this question because I had the same problem and could not find any help with it. The cigarette lighter fuse for 2004 dodge stratus sedan is under the hood in the fuse box it is fuse #2 ~20 amp. The owners manual diagram is so small you cant read what the descriptions are...So I hope this helps you all out!!
Jan 19, 2009 | 2004 Dodge Stratus
Vehicle Parts & Accessories Logo
48 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
