Question about LG DLE2532W Electric Dryer
Dryer drum needs several manual pushes to start
When the button is pushed to start the dryer, the drum will sometimes not turn, you just get a humming noise. If you open the door and manually spin the drum, then close the door, the drum will make a clunky noise and then proceed to run normally and quietly. Sometimes the manual spinning of the drum has to be done half a dozen times or more to get it started. Does this sound like a bad motor?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Or just a bad belt cheap but labor intensive
http://www.youtube.com/watch?v=7OVBi0LcrzQ
Posted on Dec 19, 2013
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
  • 135 Answers
SOURCE: dryer drum does not turn
look on The back of the dryer. If their isn't a removeable back panel then lay dryer down and look inside for the belt or pulleys. One or both are probably bad.
Posted on Jan 01, 2010
manhandy
  • 146 Answers
SOURCE: After 3 years of reliable service, my LG DLG5988W
that is the safety switch probably need to be replaced. or make sure the door is closing all the way.
Posted on Jun 24, 2009
  • 767 Answers
SOURCE: I have the LG DLE5977S dryer. When I push the
The belt could be broke or the idler spring may have come of in either case you will have to take the machine apart to find out which.
Posted on Mar 21, 2010
SOURCE: I have a LG DLE0332W Electric Dryer. I push the
I have an LG TROMM DLG and I was having the same problem. A few days ago, I had the " check filter" light come on, checked it, took exhaust hose off, and blew it out (with my leaf blower- maybe not the best tool for the job) dryer worked couple of days and then I had problem you mentioned.
My best friend engineer neighbor came over to look at it. We took top off, turned it on, wouldn't tumble, we gave the drum a push with our hands, it started, we repeated that a coupel of times and now it's working, Seems like belt is fine, motor is ok- maybe something got caught in rollers, Hopefully fixed for good now.
Posted on Aug 05, 2010
Dryer motor hums but does not turn when start button is pushed
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 24, 2011 | Maytag MDG6000 Dryer
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
Jan 23, 2011 | GE Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
Jan 17, 2011 | Maytag Dryers
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Dryer just hums
there a part inside the dryer called a capacitor i'm not sure where about on your dryer where is located but they are usually sit right next to the motor it might be white in colour with 2 clips coming off it chnge it good luck
shaun
Jan 10, 2009 | Kenmore 63942 Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
LG DLE2532W Electric Dryer Logo
231 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
