Question about Car Audio & Video
Gas leak Gas is leaking tons of fuel. Looks like it could be the line but also looks like its coming from above the line
    Problem Solver:
  • 10 Answers
Looks like oxized lines, no under coating and or winter road salts are the cause. keep undercarriage free of road salts, repair or replace lines.
Posted on Apr 29, 2013
I am smelling gas coming from my impala... i looked under the hood and found the source. it looks like a small fuel filter.. i know that isnt it but what is this device?
it could be the fuel pressure regulator and it is leaking
Take it off, go to an auto parts shop or service spares and ask for a new one of them things
Feb 27, 2016 | 2005 Chevrolet Impala
Leaking gas out of gas tank looks like it is missing a plug on the side of tank
I don't know your particular saw, but all fuel tanks are vented. Possibly the vent line or vent fitting has become dislodged and lost.
Sep 13, 2014 | McCulloch Garden
Fuel pump leak
Looks like it may be a fuel return line from the fuel manifold . It may be split or loose . Probably both . Get a new section of fuel hose and some good clips and replace it
Feb 22, 2014 | Acura Cars & Trucks
"05 Nissan Pathfinder PO455 EVAP
If those are fuel lines then fuel would be coming out. There are lines that carry fuel vapor for the EVAP system. If these lines you are looking at are the EVAP lines (sounds like they are) then this would be the cause of the large EVAP leak.
Aug 31, 2011 | 2005 Nissan Pathfinder
This error code p0457, just popped up and I have a diagnostic reader. After reading the code it said it was a bad gas cap but the cap is fine. After further looking into the problem i noticed a small fuel...
The bad gas cap is related to the evaporative emissions what happens is the gas that is not used in the engine return to the tank via the 2nd hose. The tank is pressurized very lightly by this and a sensor detects whether or not the air escapes. So if the cap is loose or there is a leak in a hose the code will set. Since you also have a leak I would start there first. The straps most likely are not cutting the tank the epa would have a fit. Most likely the the gas is coming from above the tank and working its way down the straps. Lowering the fuel tank requirs raising the car quite high. If you are able to inspect the area and reach it I think the leak would be in the gas lines above the tank. Or from the filler tubes when you fill with gas. If you can see the gas leak but are unable to reach it take it to a shop. This may fix the light if not a shop with a (smoke machine) will pump smoke into the system and search for air leaks that way. Good luck .
Feb 15, 2011 | Dodge Ram 1500 Cars & Trucks
Gas Leak under Hood on 2004 Aviator
It can only be a small area. Does it seem to be coming from the fuel rail area, which is usually chrome color. The fuel pressure regulator or fuel line. The fuel line come up the driver side firewall connects to a regulator, and then feeds into the fuel rail. Any of these connections could be the leaking source. Also one of the rubber o rings for the injector could be leaking. Look to see where it mostly looks to be coming from and feel around the pipes for the gas.
May 10, 2010 | 2004 Lincoln Aviator
It looks like my fuel lines on the top of the gas tank is leaking the metal fuel lines are rusted and thats were it looks like the fuel is leaking from....my centuary has 94k miles on it and I'm wondering...
REMOVE TANK, ALSO FUEL PUMP. UR PUMP IS STILL GD, U MAY BE ABLE TO STILL BUY THE ASSEMBLY . USE UR OLD PUMP. IF NOT, GET 1 AT THE WRECKERS, SAVE A LOT OF $$$$$$, KEEP UR OLD PUMP FOR FUTURE PUMP PROBLEM, CHARLIE
Feb 21, 2010 | 1996 Buick Century
Leaks gas onto motor whats the name of the part its above the alternator looks like a fuel line runs into it.right under the 2 in 2.4 circle peice
chances are you are talking about a fuel pressure regulator. please not drive until you get this repaired. car fires are not fun to put out.
Dec 23, 2009 | 2002 Pontiac Sunfire
Gas leaking from tank
This sounds like you have a leak at the fuel pump and sender unit, either in the unit mount or in a fuel line. Check under your back seat for an access panel if you have one then remove it and look at the pump and sender mount to see what is leaking, you may have to start the engine to get it to leak as it may only leak under pressure, hope this helps, let me know
Sep 12, 2009 | 1993 Ford Escort 4 Door
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
