Simpson ezi sensor
Rubber inside is going black and moldy looking can it be removed to clean?
SearsTechToo
  • 261 Answers
SOURCE: strong mold smell inside washer
Powder is tuff on a front loader, liquid is the way to go. One solution is to use a ratio of 2 Tbls of soap to 1 Tbls of softener as this machine uses 70% less water and this makes the solution of soap much stronger causing a build in the back bottom of the tub. Every one I have rebuilt has had to be scrapped out because of excess soap, liquid or powder. This stuff turns black and is awful. I usually use washer magic only and knowing that one use will not remove even 3 years of build up but is a process of reversing the junk. So I will by one from Walmart for about 4 bucks and pour the contents into the machine will empty of clothes and water and let it sit over night to start breaking the stuff down, then in the morning I will run hot water in the closet sink to the machine so when I start the cycle the water is hot. So after soaking you want hot water with a heavy agitation plus a second rinse and that will remove half of the junk. I usually do this every month on my top loader because of hard water and my clothes do smell much better for it
Posted on Sep 20, 2008
  • 92 Answers
SOURCE: circular grey rubber part ..
firstly u have to take the wire off it with a screwdriver unscrew it take it off then watch how the old on pulls off as there is a lip all around this rubber and it as to bed into the metal drum just see how the old one comes off once you have put the new one on put the wire back around it or it could be a metal strat wich tightens up with a screwdriver,rgds,paul
Posted on Jul 07, 2009
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Posted on Aug 04, 2009
SOURCE: We are using our Electrolux/Simpson Ezi Sensor washing
also have the same machine - if you wash with the eco rinse the clothes will ALWAYS have the soap residue on them and if you use the deep rinse then this machine will just sit there doing the very occasional agitate for up to 6 hours - can't win - have only just hung out a load and as usual there are many many dry spots on the sheets which is a daily occurence - really hate this machine and it's so called u-beaut functions -
Posted on Mar 11, 2010
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Posted on May 03, 2010
Simpson Ezi Sensor 6kg Lid locked again! want to get lid off to get wet clothes out. Undid the back screws but need to get the lid itself off -
try a thin steel putty knife along the side panels at the top some only have clips holding the top down .usually 1 per side near front
Nov 17, 2017 | Simpson Washing Machines
Manual for Simpson Ezi sensor front loader washing machine
Try Googling (simpson)(model)(manual) without parens.
Jul 11, 2017 | Simpson Washing Machines
Have Simpson Ezi loader 5.5 Is there only one water inlet valve.
there should be two inlet connections -- one for hot water (red) and one for cold (blue)
there should be two hoses with the ends color coded
inside of the fitting the screws onto the back of the machine there should be a rubber washer
that is what seals the hose onto the machine fitting
-- same rubber washer that is in any 1/2 " hose to tap fitting
Nov 21, 2016 | Simpson Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
I have a Simpson EZI Loader 5.5kg, where is the lint filter
HI just read your posting.Now the SIMPSON EZI LOADER comes in front and top loader versions.Which type is yours?Are you getting a lot of lint on your clothes?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 03, 2010 | Washing Machines
Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
Dec 21, 2009 | Washing Machines
EZI Sensor is unbalanced on every load
Problem now solved, Simpson solved it by informing me that this machine comes with 4 transit straps on the bottom of the bowl to the adjustable feet. Its not stated anywhere on the material supplied.
Dec 16, 2009 | Electrolux Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
