Question about Verona VEFSGE365DAW 36" Double Oven Dual Fuel Range with 5 Sealed Burn
I just installled a Verona VEFSGE 365 dual fuel range/oven.
Right oven works but left is not...ideas?
    New Friend:
  • 4 Answers
Got to your manufacturers instructions and check if you have a auto cook timer for the ovens, if so normally the timer needs to be set on "Manual" to enable it to function.
Posted on Feb 25, 2014
Removing the top of my Kenmore model 790
You could have asked in the original post. :>)
Look at the upper rail of the oven at the front. Look for clips that unscrew and will allow you to tilt the top backwards.
Oct 29, 2015 | Kenmore ELITE 790 30 FREESTANDING DUAL...
One burner ignitor does not work
Try cleaning the burners by boiling them in degreaser like soda crystals. Burnt food can act as an insulator to the current for the spark which is grounded through the burner. If that doesn't work, you need to left the top of the hob to check the wiring underneath.
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
How many watts does my range need or use?
Check the plate on side or back of appliance for this info!
Dec 31, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Replaced element on frigidaire oven and oven still not working
Good Afternoon Friend,
I understand you've recently replaced the elements on your Frigidaire oven and that it is still not working. May I have your model number please? The serial tag, which lists your model number, is normally located in the storage drawer, on the right side if you have a range. If you own a wall-oven please check the front of the oven, on the left side, as you open the door. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better determine what may be causing the issue at hand. Thank you! - Z
Sep 07, 2014 | Frigidaire Stove / Oven / Range Cooktop...
Why does my oven does not work but top burners are good
Not sure but newer stoves have 4 wires 2 110 and 1 ground and 1 neutral. Older stoves had 2 110 and only 1 ground. The oven sometimes used the ground a sa neutral for little motors, displays, etc. make sure that the third wire on your plug has a good ground and see if that helps
Jul 16, 2014 | GE Stove / Oven / RanCooktop Assembly -...
Oven fan will not shut off
Do a search for thermal fuse and your model. The heat can trip a fuse which will lock the fan on. Good news is it is resettable. Find the fuse and reset it.
Oct 31, 2013 | Verona Cooktops
I have a 37 year old 3+! corning range which I love. The oven heats between 25-50 high..Help!!
This sounds like replacing (or if possible - adjusting) the thermostat will fix the problem. Fortunately, thermostat technology hasn't advanced to the microprocessor level yet, so you (or your appliance repair person) should be able to find a workable replacement - assuming it isn't a real odd-ball.
Some thermostats allow for minor adjustments - but not all. Since I have no idea which oven you have - there's little more I can provide.
Oct 09, 2013 | Verona 34 in. CTG536S Gas Cooktop
The burner in question is the center back the indicator light stays on even in off mode
u may have a bad switch.. if the light stays on while all burners are off.. u will have to check each switch one by one to get the right one..
Dec 12, 2012 | DCS Professional RDU486GLL 48" Pro-Style...
Verona VEFSGE365DAW 36" Double Oven Dual Fuel Range with 5 Sealed Burn Logo
178 people viewed this question
Top Verona Cooktops Experts
Steve
Bosse Photos
Pierre Legault
Are you a Verona Cooktop Expert? Answer questions, earn points and help others
