Question about ASUS Computers & Internet
ASUS laptop plugged in but not charging - ASUS Computers & Internet
  • ASUS Master
  • 7,627 Answers
Does the battery need replacing? Have you tried another cord/charger with the EXACT same power specs? Has the AC jack been damaged due to pulling on the cord while plugged in?
Posted on Apr 30, 2013
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My ASUS t500ia will not turn on anymore. Even when plugged in. The charge light is green
Hold the power button down for 30 seconds or more. Sometimes with my asus laptop i have to do this 2 or 3 times to get it to power on.
Feb 23, 2015 | ASUS Transformer Book Flip TP500L-UB51T...
My ASUS K52 battery is at 58% and not charging why ?
Is this an ASUS charger and battery? Some ASUS laptops will not charge after a certain charge is reached, but it's usually in the 95-100% range to prevent overcharging.
If you bought an aftermarket charger, it may very well not have the amperage to charge while running the laptop.
Feb 13, 2015 | ASUS 156 K52 Notebook (AAC4001K52DRA1)
Why does my asus notbook not turn on and is blank?
Sounds like the battery is completely flat.
Ensure your charger is plugged into the mains socket and plug into your notebook. Leave to charge for about an hour, then it should switch on.
When you have finished using it, make sure it is shut down correctly and leave it charging over night for a full charge. (When it is switched on whilst charging, it takes much longer to charge.)
Jun 24, 2014 | ASUS B50A-B1 (90NQ9A1232244EQL150YB50AB1)...
My asus x551c notebooksays plugged but not charging
The battery will charge only when the laptop is off. This stops cooking the batteries
May 03, 2014 | ASUS A52F-XE2 Notebook
Asus u53
Could be a bad battery or charging circuits of motherboard. If laptop boots up when plugged in check under your control panel for power options then look to see if it shows charging. If it shows your charging but the battery doesnt charge then you have a bad battery
Mar 21, 2014 | ASUS Computers & Internet
96% plugged in, not charging Hi all, my Asus
Laptop battery do have a specific lifespan, specially for older units. Still, you can check that your charger are working properly, using a voltmeter (do check the outer label of the charger for actual voltage output).
You may try to do my Tips on Laptop battery
Good luck
Tedmac
Oct 17, 2013 | ASUS Computers & Internet
Despite of new battery my Asus PRO50 won't charge a 100%
Is it a replacement battery? Are the specs the EXACT match, DC volts and Amps? Some inexpensive batteries do not work well with your laptop, it's a Connector/ pin thing, they don't communicate with the laptop. Try pulling the plug and drain the battery and recharge. Cycle it a 4 times, drain/ recharge. Does your BIOS setup have a Battery Learning section?
Dec 13, 2012 | ASUS Computers & Internet
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
Battery charging problem on my asus x50rl, onto 2nd battery now, initial charge ok but will not charge up now
you may need to recalibrate the battery, to do this you need to run the laptop until it shuts down due to power, turn it back on and on boot press f2 or w/e your bios key is and plug it back in then let the laptop run until it dies again. plug it in and let it charge completely. i hope this helps
Jan 03, 2010 | ASUS Computers & Internet
Computers & Internet Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
