Question about Emission System for Land Rover Freelander
Reverse gear not working on landrover freelander 2006,but if you put th D to drive the car move only when you put the reverse dont want to go way ?thank
    Top Expert:
  • Land Rover Master
  • 50,503 Answers
Run fault codes and look for faulty reverse sensor / servo. have a pressure test done on the gear box to eliminate any internal damage / adjustments.
Posted on Aug 17, 2013
Transmission slips in reverse
I would have a transmission shop look at it. It could be as simple as a service, but its hard to tell without getting it on a lift.
Jun 17, 2013 | Land Rover Freelander Cars & Trucks
2003 landrover freelander trouble wit reverse
6_18_2013_2_40_37_pm.jpgThis is the kickdown adjustment
Jun 17, 2013 | Cars & Trucks
What operate the 4x4 in the transfer box of the landrover freelander 1.8 Petrol. The switch on the gear lever works but the wires are disconnected and I see no switch or valve on the gearbox or transfer...
Freelander is permanent 4 wheel drive. The switch on the gear lever is for downhill decent control. These are usually diconnected when there is a problem with one of the ABS wheel sensors not working, causing three warning lights on the dash to display. Google Freelander Three Amigos.
Mar 18, 2013 | Land Rover Freelander Cars & Trucks
When I put my gear into Reverse, Netrual and Drive the gear is getting stiff to move. Why is this happening?
If you mean the shifter is getting hard to move, its probably the shift linkage sticking, try a couple squirts of pblaster or other penetrating oil. If the motion of the vehicle is getting hard to drive in reverse and drive the torque converter may be the issue.
Jun 03, 2012 | 2006 Ford Five Hundred
When I put my 2006 ford Five Hundred in Reverse, Netrual and Drive, the gear is getting stiff to move. Why is this happening?
Has Coke or anything that goes sticky been spit around gear shift? I have had this before & had to pull console apart & clean with spray & wipe.
Wher do u put oil in a automatic gearbox in a landrover freelande td4
im a girl (girlie girl) - need to put oil in my 2006 landrover freelander. Help! I know where it goes and have the right oil. Any advice? Also, the guy who came out to charge battery happened to check the oil and it was bone dry....if i put four quarts am i safe to drive...i see no leakage under car.
Nov 04, 2010 | 2002 Land Rover Freelander
How do you replace battery in the key for landrover freelander 2000
just take it to a battery outlet were they sell you batterys for your car and for everything else dont do it your self you can break it or damge the parts inside the key
Jan 11, 2010 | 2003 Land Rover Freelander
Landrover freelander year 2000 light on dash board shows car tilting down hill with question mark
1)it is possible that your hill desent has been turned on. remady check gear stick sliding coller has not been engaged, press yellow switch and pull coller upward. 2) connector may have become dissconected from switch. remedy unscrew gearnob and press yellow switch and pull coller up and off , check wireing and connector the put all back together. next check your throttle peddle switch and or your reverse switch may need to be changed
Nov 22, 2009 | 2002 Land Rover Freelander
Emission System for Land Rover Freelander Logo
175 people viewed this question
Top Land Rover Vehicle Parts & Accessories Experts
Bill Boyd
Thomas Perkins
Thomas Perkins
ray gallant
Are you a Land Rover Vehicle Part and Accessory Expert? Answer questions, earn points and help others
