Question about Vehicle Parts & Accessories
Power windows not working
Well my passenger side front and rear power windows aren't working but the driver side front and rear power windows are working and I was just wondering if any one can tell me how to fix it.
    New Friend:
If you provided year,make,model it would be helpful.
Start with a wiring diagram too see if there is voltage at the fuses then continuity at the switches or child safety controls.
You can do this with a multimeter.
I've experienced the culprit to be bad contacts in the switches.
Posted on Mar 17, 2015
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 11 Answers
Replace motor inside door panel
Posted on Apr 30, 2013
2 Suggested Answers
  • 6 Answers
SOURCE: Power Window issues on 2002 GMC Sierra
try putting some white lithium grease on the tracks
Posted on Jul 05, 2012
Master switch power window and locks
master switch faulty if other switches works windows and locks.
Jan 15, 2013 | 2006 Jeep Commander
2003 cadilac deville driver window off track. motor seems to work but window will not go up.
Window regulator is bad in the drivers door . Do you know what a regulator is ? The Trainer 24 Power Window Troubleshooting Do you know anything about automotive electrical testing ? How to read an use a wiring diagram ? Do you know there are two side to a electrical circuit ? B+ voltage an a ground side . Plus there is electronic control modules and class 2 serial data network involved . When you push the switch for a window othen then drivers window on the drivers door . a class 2 message is sent to the other doors modules . The correct module will then open it's window .
http://www.bbbind.com/free_tsb.html Check out free wiring diagram here .Enter vehicle info . year , make , model and engine size. Under system click on body & accessories , subsystem click power windows . Click search button , then click each link one at a time .
Mar 27, 2017 | 2003 Cadillac Deville
Power windows and locks do not work
The power windows are protected by 50A fuse 12 in the power distribution center. The orange/white wires from the PDC go to the driver door module and the pasenger door module. The driver door module controls the front power window motor directly and applies power to the driver rear power window switch to allow passenger control of the rear power window. Similarly, The passenger door module controls the front power window motor directly and applies power to the passenger rear power window switch to allow passenger control of the rear power window. BUT, operations can be computer controlled as part of the access control/theft deterrent system.
The power door locks also are protected by 50A fuse 12 in the power distribution center. The orange/white wires from the PDC also go to the driver door module and the pasenger door module. The driver door module controls the driver door lock motor/ajar switch. The passenger door module controls the passenger front door lock motor/ajar switch and supplies power for rear seat passenger control of the left and right rear door lock motor/ajar switches.
In short, if power from the fuse is getting to the door modules all windows and doors should work. If not, there may be a defect in the modules, the separate control switches, or even in the motors.
Sep 09, 2012 | Jeep 2004 Grand Cherokee LAREDO 4WD
F250 Power windows and wipers
What year is the vehicle ?
Jul 06, 2017 | Cars & Trucks
The passenger side brake light, and passenger side (front and back) window control doesn't work is it a fuse?
Well, the short answer is no.
The lights and windows are are different fuses.
There's a slight chance you have a problem with a ground wire on that side, but I doubt the two problems are related.
I would check the light for power and ground, and look at the window switches for power and ground. The windows are powered thru the driver switch on most cars.
Jul 17, 2012 | 2004 Oldsmobile Alero
2004 Malibu Maxx-Driver side and rear power windows will not go down. The power window controls for the driver side and both rear windows do not work. The only window that works is the front passenger,...
well you can try "jumping" the correct wire to see if window got up or down... this will tell u if switch is bad... but I would just go but a new master switch... try that before you cause more damage..
Sep 05, 2017 | 2004 Chevrolet Malibu Maxx
2003 Elantra GSL power windows don't work.
could be the driver side master window switch... if the driver side window switch assembly is broken then the windows will not work... try using a test light to see if you got power to the with and and ohm meter to check all four switches on the drivers side
Jul 11, 2010 | Hyundai Motor 2003 Elantra
1998 VW Jetta GLS Manual Trans. The driver side power window won't roll down. From the same switch the front passenger window won't up but will roll down. The passenger side switch works fine; passanger...
If you have a multimeter you can go to the underside of the master panel in the drivers door and independently check the switches for voltage or with no power to the switch assembly check for continuity. Good place to start. If you get continuity to through the switch then you need to check power to the window actuators in the doors.
Jun 27, 2017 | 1998 Volkswagen Jetta
Windows won't roll down
Does the rear window work from the passenger switch?
Oct 07, 2009 | 2003 Cadillac CTS
Vehicle Parts & Accessories Logo
159 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
