Question about Garden
Hard start hard to start
  • 7,482 Answers
Hi scarborotb. Here are a few thing to check
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 29, 2013
Does a Goodman DSXC180601 5-ton A/C unit require a hard start? System has a TXV. I have been told hard starts could void the warranty
hard starts are not mandatory but they do help to save the compressor if it is having a hard time starting
its just a boost to help it start
and it shouldn't void your warranty they are to help it start nothing else
Apr 19, 2015 | Goodman Heating & Cooling
1997 Malibu 3L V6 Suddenly hard to start Suddenly hard to start
Could you give more detail as to what it's doing exactly? Is it having a hard time cranking the engine or does the engine crank but not want to get started?
Aug 01, 2008 | 1997 Chevrolet Malibu
Car is hard to start and when starts chugs and brake becomes hard to push
Sounds like bad vacuumed leak because of brake being hard.check that the hose from power brake diapham on fire wall to intake manifold in on not got a hole in it and if it seems ok pull hose off brake unit and plug and start.good luck.if that solves it replace brake booster.
Mar 22, 2014 | 1999 Cadillac DeVille
It's not hard to start..it's hard to go in 2 and 3 gear
After start go to D and then to 3 and 2. Usually 3 should get you enough power up or down a hill. What is hard about changing gear?
WHAT vehicle is it?
Jul 20, 2013 | Cars & Trucks
93 gmc jimmy hard starting
"Hard starting" is a very vague description of the problem. There are MANY things that can make an engine hard to start - ranging from a weak battery to a bad fuel pump, to worn-out spark plugs or a plain, worn-out engine...
The only "solution" I can offer at this point, would be to recommend doing some diagnostics to determine at least which system in your vehicle is the cause of the hard starting.
May 26, 2012 | Cars & Trucks
1997 chevy venture hard to start
"hard to start" is a very vague description of the problem. There are MANY things that can make an engine hard to start - ranging from a weak battery to a bad fuel pump, to worn-out spark plugs or a plain, worn-out engine...
May 25, 2012 | 1997 Chevrolet Venture
What does "hard start" mean
The compressor is having trouble starting. You can wire in a hard start kit to help the compressor start. Its easy the hard start has two wires one goes to Common on the capcitor and the othe goes to the HERM terminal on the capacitor.
Jul 19, 2011 | Heating & Cooling
My hard drive is "hanging up" and sometimes does not start. The computer will start, keyboard light momentarily lights but hard drive will not start. The only way I can seem to get it started...
There is a possibility your hard drive is failing.Go to the website of your hard drive manufacturer and download a diagnostic utility. Run the diagnostic utility to determine whether the hard drive is in good condition.
Nov 10, 2008 | HP Computers & Internet
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
