Question about Plumbing
Handle leak Leaking at the handle price phister
  • 26 Answers
You need to replace the "guts" go to your local hardware store (Lowe's/Home Depot) and go to the plumbing section. They should have replacement parts for your faucet.
Posted on May 06, 2013
SOURCE: how to take handle off of Grohe Lady Lux Cafe-took screw out-handle is stuck
I soaked the connection between the handle and the valve body in a penetrating oil for several hours and eventually used more force than I hoped to use to remove the handle. Once the handle and end cap (part 09 209) were removed, I could see that the valve assembly (part 46 048) was loose which caused water to leak from the seals (part 46 209) between the valve assembly and faucet body. So I tighted the screws that hold the valve assembly to the faucet body and the leaked stopped.
Posted on Oct 12, 2008
  • 14 Answers
SOURCE: Leaking tub spout single handle volumne/thermostat
See if you can give me a head on picture.
From the top it looks like it could be a Kohler or Grohe.
Thanks,
sanray
Posted on Dec 28, 2008
  • 686 Answers
SOURCE: KITCHEN FAUCET (single handle PRICE Phister ) suddenly quit flow
Take it apart and clean out calcium lime or rust build-up. Also check to be sure your shut-offs are clear and running well
Posted on Jan 09, 2009
  • 659 Answers
SOURCE: Single handle faucet is leaking from the center.
If you remove the handle, you will be looking at the stem that you described. You will see the white plastic piece that surrounds that stem as well. If you go one more step outside of that is a retaining ring that is usually either grey or white that has a few notches out of it. This is a tension ring and when tightened, it will stop the leak. There are two small washers with springs that sit below the ball with the stem that can be replaced if you experiance a leak from the spout and not around the stem as you described. Hope this answers your question. Don't forget to rate the solution when your done! Have a very blessed night.
Posted on Apr 02, 2009
  • 74 Answers
SOURCE: price phister marielle kitchen faucet is leaking
Take the faucet back to where it was purchased as I believe PF has a lifetime warranty on their products.
Posted on May 03, 2009
Remove handles from price pfister treviso double handle faucet
replace rubber seal in tap need to unscrew the nut to get at it
Nov 27, 2011 | Plumbing
Kitchen price pfister with spray that comes out of arm. Need to take off on/off lever at top to look for cause of leak. How to remove the on/off lever?
If you will look .....first thing would be a good idea to turn water cufoffs under the counter to off position....then remove handle,to do this there should be a set screw (hexagonal screw) on the bottom side of handle lever a heagonal wrench will be needed to remove handle...... Now that you have the handle off you can turn the cold side of the cutoff on or the hot side to find out which one is leaking hot or cold .......if indeed it is a washer ( rubber cup) that is leaking.......hope this helps...
Sep 05, 2011 | Price Pfister Plumbing
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
My faucet is leaking from the pulldown where the hose is conected to the spout ive tried to take it apart is there a special way to take it apart
before you take it apart ,I want you to check,the pullout handle first,because most of the time ,all that is wrong is that little1/2-5/8 in washer between the handle and the hose,It usually runs down the hose ,and might apear to be something else leaking under the sink.If your correct,and it is leaking where you said.Some of the newer faucet have a clip that just pushes together.So you need it fing the clip,and push it in.
Apr 12, 2010 | Price Pfister Ashfield Single Control...
Kitchen Faucet Leak
The stem and washers inside the faucet need to be replaced.
If you Do it yourself the parts typically will cost you less than 20 bucks.
Most plumbers will charge 75 to 100 for this relatively simple Job.
You can order parts directly from the manufacturer, or from a local plumbing supply house.
The faucet may still be under warranty and the parts would be free. Here is ther number for Price pfister.
1-800-PFAUCET (1-800-732-8238)
Aug 23, 2009 | Plumbing
I have all 3 new shower valves purchased from home depot to replace old and they are all leaking from the threads where you tighten down vave stem.Ive tried thread tap they still leak...
Most Price Phister valve cartridges have a plastic washer or "O" ring at the base of the cartridge, where it screws into the valve body. Replacements should be available at H/Depot, Lowe's/similar.
Regards, --W/D--
Jul 13, 2009 | Price Pfister Plumbing
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Jan 09, 2009 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
79 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
