Question about Emerson LC320EM9 32 in. LCD HDTV
My emerson lcd tv wont come on it worked fine yesterday but when i go to turn it on today the green light blinked twice than red once but never came on
My Emerson LCD TV blinks green twice than red once but wont come on
    Top Expert:
  • Emerson Master
  • 75,304 Answers
If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. Blinking codes to many brand TVs are described in detail. http://electronicshelponline.blogspot.com/
Posted on Apr 29, 2013
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
dsacco86
  • 1077 Answers
SOURCE: I have a LCD Color TV, but when turn on, green
The most common problem is the Power/Backlight Inverter Board. There are 6 mini transformers on the board, one goes bad and the TV will turn itself OFF automatically for " Protection Mode". Replace the whole board or replace the bad mini transformer.
Part number#
Whole board, BA71F0F01042
Mini Transformer, LTZ2PC0MS008
Posted on Mar 02, 2010
  • 4234 Answers
SOURCE: green light flashes twice then turns red
Please ignore the first solution as that blink code definition is for a Sony CRT based set, NOT an Emerson.
Carefully examine the LCD panel itself with a flashlight and look for small cracks. Based upon your description of events, I think that the panel is actually cracked. This usually only prevents a picture from showing. The red lights are an indication of an internal problem and the set is in shutdown to prevent further damage.
Without seeing the actual unit, I cannot make a definite diagnosis, but I would initially suspect a power supply problem that may be relatively cheap to fix. If the set is relatively new, I'd invest in a detailed repair estimate. Post the info here from that estimate and we may be able to walk you through the actual repair.
Dan
Posted on Jun 22, 2010
budmrtn
  • 11361 Answers
SOURCE: My LCD Emerson don't turn on and is just 4 monts
Get it repaired ASAP under warranty, this is a sign of a lemon set.
It will void any warranty if you open it up.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Oct 21, 2010
Tv blinks green twice than red once but doesn't come on at all
It sounds that the main digital board has damaged. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Apr 28, 2013 | Emerson Televison & Video
Emerson lc320emx trouble turning on
You probably have an internal power supply problem
Mar 04, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Green light flashes twice then turns red
Dan
Jun 22, 2010 | Emerson EWL3706 37 in. LCD Television
Emerson LC320EM82 S red light will come on and when you go to power the tv on it blinks green and never turns on
Power supply board is dead,if green light on keep blinkings,notthing come on.Power green light is solid,nothing come on.Than ur Tuner signal board is dead.
Feb 09, 2010 | Emerson LC320EM8 32 in. LCD TV
It will power on but then turn right back off it worked fine yesterday
One of four things happen when these lcd's get power problems. 1. They either go completely dead[no power with no lights] 2. Little green light will blink and go back to red with dtv briefly showing and then the tv screen go blank 3. Same as # 2, but with screen staying blank. The fourth is extremely rare, which is a shorted panel that makes the tv set behave like it's getting no power. All signal a bad tv, and the fourth is not usually repairable, requiring a whole new panel. I hear that power flows thru the panel, so that would explain how sometimes it will short out.
Apr 28, 2009 | Emerson EWL3706 37 in. LCD Television
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson 32 inch lcd
i have your answer!!!!!!!!!!!!!!!!
use the PRODUCT WARRANTY call emerson and have it sent back, then your like oh wow it works like new( and it will be a new one) yay thank you so much guy on the net for telling me about the PRODUCT WARRANTY
Oct 21, 2008 | Emerson EWL3706 37 in. LCD Television
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson LC320EM9 32 in. LCD HDTV Logo
240 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
