Question about Dirt Devil 12 Amp HEPA Filter Vacuum Vacuum
No sucktion into bag, air coming out the sides
No dirt goes into bag. It picks up dirt but does not go into the bag. Strong air is coming out of the sides where there is the vent. No sucktion in the long tubes that you use as attachments.
3 Suggested Answers
  • 7 Answers
SOURCE: not sucking up dirt in upright position
if there is dust flyin around the vacuum u might try lookin for clogs on the bottom where the beater brush pushes the dirt in and maybe where the dirt goes into bag ive used wire clothes hangers to free em up works..hope this helps
Posted on Dec 17, 2008
SOURCE: This vacuum sucks literally
did you by chance figure out what was wrong? my featherlite does the exact same thing and i cannot figure it out.... ugh
Posted on Jan 02, 2010
My Oreck XL vacuum does not have enough suction to pick up dirt. Any suggestions to remedy this problem? The belt is strong, the bag is not full, and there do not seem to be any obstructions.
Turn the machine on and be sure the bag expands quickly and fully like a balloon. If the bag does not fill with air, or is soft, there is probably an obstruction inside the handle tube or fan housing. Disassemble the handle to check for blockage, or remove the bottom plate to check the inlet to the motor fan.
Jan 19, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Machine screams /not enough sucktion
This is probably a plug in the suction side. if it is an upright with no hose, try removing the bottom where the brush is and look for an obstruction where the air goes up into the vacuum. On a canister vacuum check the wand then the hose for something inside blocking the air flow. On bag types, make sure the bag is not full or the inlet to the bag is not plugged. Hope this helps
Jan 03, 2011 | Vacuums
Kirby won't pick up dirt when I vacuum
Very likely the air flow through the machine is clogged. Remove the bottom plate, inspect the air passage going into the motor case. Remove the bag and inspect the air passage that goes into the bag. A stiff wire (coat hanger) with a hook bent on the end is handy to dig out the clogs. When it looks clear, start the vacuum again without the bag (take it outside--it will blow debris everywhere for a little while). Hope this helps!
Mar 30, 2010 | Vacuums
Why does my miele 700 revelution hoover keep cutting out? The bag is not full just loses power?
  1. i have a miele revolation hoover, it doesnt pick up. it has hardly no sucktion. where and how do i get the filter out to clean it??? it was given to me working. ive changed the bag so thats not the problem. and checked the hose. still no joy. need sucktion.. Thankyou jacqui
Jan 01, 2010 | Miele Revolution 600 Bagged Canister...
The brush spins but the the dirt is not getting into the bag. i cleaned the hoses now it's not sucking anything up.
If the motor is running you should get some kind of sucktion, if no sucktion or wont blow any air out, check the house making sure is clear of any obtruction, the best way is looking in the house by have one person hold one end and other pull the house straight and look to see any obstruction. if it seem clear, check the motor attach to the fan, yep you have to take the cover to the motor off with phillips screw driver in order to see what causing motor not to **** although the motor may not be attached to the fan; could be loose and not spining the fan to create any sucktion. hope that help some..good luck
Jul 12, 2009 | Vacuums
My kenmore hida filter vacuum cleaner no longer has the sucking ability it used to have. It is only 4 years old and has worked extremely well up until this week. The motor is functioning well, as is the...
well i've hade one come in a while ago and it didn't have good suction so I looked at the bag it was buljing w/ dirt so I put a new bag in it and it had better sucktion but still not good enough so I cheched the fabrick filter and it was dirty too so I washed it and it had even better sucktion so try the paper filter on the end too and if your vacuum still haves bad sucktion try looking if the hose is clogged buy putting your mouth on the end and blowing through it i recomend whiping the end off befor blowing if hard to blow it is clogged, if clogged i would put something thin like a metal rod or or a stirty stick to push the dirt out i'm sorry if my info didnt work out :D
Jun 12, 2009 | Kenmore Whispertone 23312 Bagged Canister...
My vacuum will not pick up even fuzz on the carpet
If the suction is strong through the hose and its still not picking up, then something is definately clogged despite the strong suction and rolle brush. Check all inspection tubes including the main dirt channel behind the roller brush. You may find something that keeps getting in the way when dirt or hair is trying to bypass through.
Jan 23, 2009 | Kenmore 31913 Progressive Direct Drive...
Not picking up dirt.
There is a Clog in the machine...
Somewhere between the motor and the bag.
When you use the machine, the dirt picked up by the roller has no place to go but backwards.
You will need to disassemble it and look for the clog.
Nov 22, 2008 | Oreck XL2200 Bagged Upright Vacuum
Vaccum
Check the hose for a clog, also check the dirt inlet down by the brush roll for a clog. If bagless, the filter inside the tank may look good, but if it is old then you may want to replace it.
Dec 27, 2007 | Vacuums
Dirt Devil 12 Amp HEPA Filter Vacuum Vacuum Logo
22 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
