Question about Craftsman 10" Table Saw
Degrees Hard to tilt to 45 degree angle. How can I make it easy to tilt?
    New Friend:
The owner of Inline Industries (he invented the PALS product that lets you get a precision alignment on a contractor saw) has a video that shows how to add grease fittings that will make blade raising, lowering and tilting very easy. Check him out. He sent me the video when I bought the PALS.
Posted on Jun 15, 2013
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • 5 Answers
SOURCE: craftsman model 708100 table saw tilt lock won't stay locked
Try removing the lock knob and putting a toothed lockwasher on the shaft. reinstall the knob.
Posted on Dec 21, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a Contractor's Craftsman
yes there is, first I would unplug the tool and tilt on its back and thoroughly try and clean the debris from the undercarriage. Then go to managemyhome.com and download a manual for this, I was looking at page 55 and it talks about how to reset the saw to make square cuts. Let me know if you need more assistance
Posted on Aug 30, 2010
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Oct 12, 2016 | Saws
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 90 degrees
stage 3 ... angle tighten + 90 degrees
stage 4 ... angle tighten + 90 degrees
stage 5 ... angle tighten + 45 degrees
Feb 26, 2015 | Opel Corsa Cars & Trucks
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
What is a compound miter saw?
A compound miter saw has a rotating vertical pivot allowing the cutter head & blade to be tilted (or beveled) sideways in addition to the horizontally rotating table. This allows vertical & horizontal angled cuts as well as cuts angled in both planes.
Jan 28, 2013 | Saws
If an angle of a parallelogram is one- third of its adjacent angle, find the angle of the parallelogram
Since the two adjacent angles of a parallelogram must add to 180 degrees, the two angles have to be 45 and 135 degrees respectively.
Nov 02, 2012 | Office Equipment & Supplies
What is the reference angle of 225 degrees and 15'
The answer to this is 45 degrees and 15' i.e. forty five degrees and 15 minutes. Each degree is split into 60 minutes. So that 15' would be 15/60 degrees. that means 225 degrees and 15' is equal to 225.25 degrees. The reference angle is given by = 225.25 - 180 degrees which is equal to 45.25 degrees. This is in fact 45 degrees and 15'.
Please vote for the answer!
Jun 28, 2011 | Computers & Internet
Cutting 45's on my Dewalt 744
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
Feb 28, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Finding the length of a triangle
might try
(54tan)/45
I don't have a calc that will do it or I would try it and see.
Jul 31, 2008 | Office Equipment & Supplies
Craftsman 10" Table Saw Logo
102 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
