Question about Frigidaire ATF6000ES Front Load Washer
Ltf2140e the signal panel for this LTF2140E model just started beeping during the cycle. we have had this unit for 8 years, can not figure out why the beeping during the cycle, it seems to still continue in the cycle well enough, thought maybe the load was too big or the door wasn't shut well, but that doesn't seem to be the problem. is there a "reset" of some sort or can you explain the problem thank you
  • Official Brand Answer
  • 4,342 Answers
Hello Mike - Typically, if the water temperature combination is not appropriate for the cycle selected, the status lights will blink and signal will beep 3 times. Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to beep. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Posted on Apr 30, 2013
2 Suggested Answers
SOURCE: waser will not spin, belt ok and visually seems to be ok....
sounds like motor control board could be bad.
Posted on Nov 03, 2008
Machine wont stop beeping
Press the beep button if you can see one. It would say loud, medium or off.
Apr 01, 2013 | Frigidaire FEX831CS Top Load Stacked...
Beeping sound when cycle is finished just started after 8 years. how do I turn it off?
Welcome to FixYa.
I think can answer your question..."beeping sound when cycle is finished just started after 8 years. how do I turn it off?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
? If the display blinks with a "0", you will hear
no signal (indicates OFF).
? If the display blinks with a "1", you will hear a
LOW volume signal.
? If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
? If the machine beeps, then the Cycle
Completion Signal has been enabled.
? When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Nov 06, 2010 | Bosch SHU9915UC Dishwasher
Beeping Sound on Dryer
okay, this same problem happen to kenmore elites, the touch panel will automatically come on and beep even when it suppose to be off, replaced not the board but the touch panel and you will be okay.
Aug 17, 2009 | Frigidaire FEQ1442ES Electric Dryer
It won't stop beeping all the time. We have tried everything. It beeps 3 times, all the buttons light up and it makes me crazy!! I want it to beep when the load is done - that's it.
When the Cycle Signal Control is ON (turn off) a signal will sound at the end of each cycle and
during the Press Saver setting (some models). The volume is adjustable on some
models.
Jul 18, 2009 | Frigidaire FEQ1442ES Electric Dryer
Cycle Signal Volume beeps from loud to soft
This is a common and very well known problem with the Oasis. You will need to replace the operator interface board inside the control panel to resolve this issue. The board is located directly behind the control knob. If you post back with your model number, I can research a part number for you, give you info on where you can order a replacement, and give you guidance on how to replace the board yourself.
Feb 12, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Loud/Soft signal
all i can figure is it is a strange method by kenmore to alert the user to throw in an antistatic cloth that gives softer clothes (clothes softener sheets)
May 25, 2007 | Kenmore 67052 Dryer
Frigidaire ATF6000ES Front Load Washer Logo
75 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
