How to change the captions on my Sandi Com3101A remote control?
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Download the user manual to your set by internet. It has all details.
Posted on Apr 29, 2013
How to turn off closed caption
Closed captioning is an option usually selected during initial setup of a TV. If you turn off the TV speakers, there is a pause and closed captions begin. To change this, go back to te TV setup procedure and deselect CC
Dec 13, 2012 | Akai New Original KC01A1 Remote Control
Cannot remove the closed captioning
You must have its original remote control to close the closed caption.
May 07, 2012 | Sony RM-Y915 Remote Control
I need the manufacturer's code for SANSUI Model COM3101A in order to program my Comcast remote.
The remote control that you use for your Comcast box will not operate all functions of the TV sice its a combo model. Your best bet is to purchase a universal remote control from the following website. There are 3 different versions of your TV's model number so make sure you choose the correct one for proper operation. Good luck
http://www.remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=13116091656740
Jul 25, 2011 | Sansui COM3101 13" TV/VCR
We have tried several times over thelast few months BUT can NOT get the close caption to work....HELP!!!
Hello
There is a button on the remote control of your TV marked {CC}. This button is used to select the closed caption option to On and OFF. Presing it repetedly will change the options as described below.
CC/Stop - This button will select the Closed Caption menu
in the TV mode. Options include the following: OFF, CC1,
CC2, CC3, CC4, TT1, TT2, TT3 or TT4. Additionally, this
button stops the CD, DVD or VCR when the component is
activated with the remote control. If it doesn't work, means that button on your remote control is not working, and the remote control should be replaced. OK.
Feb 17, 2011 | Vizio L37 Television
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Remote and caption problems
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
http://tv.manualsonline.com/manuals/mfg/philips/19_inch_color_tv_cover_l9_pr1903c1.html
Dec 02, 2008 | Philips Magnavox Learning Universal Remote
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Sep 28, 2008 | Sansui COM3101 13" TV/VCR
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Remote Control Help
ON YOUR REMOTE CONTROL PRESS THE MENU BUTTON THEN GO TO AUDIO - CAPTIONING - OFF THIS SHOULD REMOVE THE CAPTIONING. LET ME KNOW IF I WAS ANY HELP...
Jun 21, 2007 | Jensen JER-422 Universal Remote Control
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
