My Toshiba laptop wont POST
My laptop will not turn on at all. The power light and the battery light is on but other than that I get nothing when I push the on/off switch. The CPU fan doesn't come on. It makes no attempts to turn on no sounds nothing.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
Sounds to me like a fault on the Primary Circuit Board. to test if it's the motherboard, try unplugging the laptop, turning it upside down, removing the battery, taking the RAM out of the pc and starting the laptop without and RAM inside it. if you dont hear the motherboard beeping it's not a good sign :(
Posted on Apr 28, 2013
jaye_ellen
  • 591 Answers
SOURCE: Toshiba laptop does not run, just amber light blinking
Did the computer ever work? Have you checked that your memory is properly seated? Remove the bottom plate that reveals the memory modules, pop both loose then back in. Try to restart. Is the battery fully seated?
Posted on Sep 20, 2009
  • 15 Answers
SOURCE: Toshiba A135-S2276 Black screen,only lights on
i have encountered this problem before on many laptops and sometimes your monitor can just go bad or a piece of bad hardware in your laptop but in my case most of these problems are the monitor going bad. how old is this laptop
Posted on Nov 20, 2009
  • 2567 Answers
SOURCE: toshiba laptop a210-15k wont turn
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
djbr1ck
  • 158 Answers
SOURCE: E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
Posted on May 12, 2011
bronk50
  • 27725 Answers
SOURCE: HP compaq 6730s laptop won't turn on
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
might be getting hot
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you
Posted on Dec 10, 2011
Toshiba Satellite A60 wont power up
It looks like some divece in your laptop dont pass POST test. Tech support from Toshiba required
Sep 23, 2009 | Toshiba Satellite A60 Notebook
Toshiba wont power on
try turning off and then remove battery and plug in a/c cord.turn back on..still nothing let me knowRICHARDM69
Aug 24, 2009 | Toshiba Satellite A135 Notebook
Packard Bell easy not wont turn on
it is not charged or its battery has a loose connection
Jul 22, 2009 | Toshiba A15-S1292 Notebook
Wont turn on.
plz try by removing the battery and try to power up if the problem is not solved then you have to go for servicing
Apr 29, 2009 | Toshiba Satellite A300-0CF035 Notebook
Toshiba quosimo f45. laptop wont boot at all ,fixed once by them
hi there,
dont panic brother,
try theses things.
--> take out battery
--> connect the power cable
--> wait for a minute
--> turn it on
--> it will work
if not
--> take care power cable out
--> put the battery in
--> turn it on
--> and it will work (try to move the lid up and down)
if not
--> charge the battery dont turn it on
--> when its full take of the power cable
--> wait for 30 sec
--> turn it on
--> it will work ((try to move the lid up and down)
if not
--> keep the power cable
--> turn it on
--> it will work (try to move the lid up and down)
best of luck
Mar 23, 2009 | Toshiba Qosmio F45-AV410 Notebook
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
Satellite A135-S4427 PC Notebook wont start at all
it might be because your laptop is not able to complete post (power on self test), moreover have you tried holding the power button down for 15 sec without the battery and ac adapter and then trying to start
to troubleshoot further you should contact a local technician
Further Queries are welcome
Feb 20, 2009 | Toshiba Satellite A135-S4427 Notebook
Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Jan 21, 2009 | Toshiba Satellite A15-S129 Notebook
Power on problem
First that u need to do is to remove the battery from your toshiba laptop. Plug in the AC adapter alone and power it on. If it works, then u need to check your battery. If the notebook wont power on with the AC adapter alone, then i think its a NO POST issue. The motherboard needs to be checked.
Sep 17, 2008 | Toshiba Satellite M115-S3094 Notebook
Power
ok..remove battery..try it on ac alone..
Feb 19, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
