Question about Google Nexus 7
Resetting instructions the screen seems to be stuck on the loading screen which only says GOOGLE with black screen in white letters. I let it die completely and then plugged up for charging, but that didnt fix the problem.
You could try doing a factory reset and then see if the device will turn on:
  1. If your tablet is on, power it off.
  2. Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power). You will see the word Start with an arrow drawn around it.
  3. Press Volume Down twice to designate Recovery mode.
  4. Press Power to restart into Recovery mode. You will see an image of an Android robot with a red exclamation mark.
  5. While holding down Power, press Volume Up.
  6. Use the volume keys to scroll to "wipe data/factory reset" and press Power to select it.
  7. Scroll down to "Yes - erase all user data" and press Power to select it.
Source: https://support.google.com/nexus/answer/2668187?hl=en
Hope that helps!
Posted on Nov 05, 2013
My tablet wont come on. whenever i turn it on it just comes to the loading screen and says system loading. then it wont go any further its stuck on the loading screen. what's wrong it?
Sounds like a previous update did not finish installing due to being switched off in mid stream or it got corrupted.good news is you can reset android tablets to factory settings...bad news is you will lose all you settings and apps which you will need to reinstall once it is up and running.most tablets reset in the same way.
switch off ...then whilst holding the up volume and the home button hold down the power button then continue holding just the vol up and home button.it will display the robot then you can let go of all the keys and follow on screen instructions to reinstall factory reset.
some tablets are a little bit different to reset...instead of volume up its volume down.if you google your make and model of tablet it will describe correct procedure...one last thing...do not panic if it doesn't reset first time...some Chinese based tablets may take two or three attempts to reset.
Jun 11, 2015 | Tablets & eReaders
How to factory reset a contixo tablet ?
Look around the tablet to see if there is a pinhole along the edge or back. If there is, then you can carefully insert a straightened paper clip to reset the tablet. Normally from off condition, insert paper clip and press power button.
If no pin hole, from an off condition press and hold the volume + and the power buttons until it boots. Follow any directions presented.
I am sure you have checked your manual, but you may want to look again for any specific reset procedures.
Mar 31, 2015 | Contixo Q102 10.1" Quad Core Google...
What do I do if my tablet won't turn on?
Try resetting your tablet. Instructions are here: http://smallbusiness.chron.com/reset-google-ematic-tablet-68693.html
Mar 09, 2015 | Ematic 7" Touch Screen Tablet
How do you fix a vivitar camelio if its screen is white
hello have you had a look on google how to do a hard reboot or youtube may be, or yr tablet will have a reset hole, very small in the side of yr tablet ,when turned on put a thin pin into the hole and press gently and you should feel it click,if this fails then hard reboot.
hope this works for you
Aug 11, 2014 | Tablets & eReaders
Samsung tablet 8 gigabyte white stuck on black screen saying Samsung. How do I fix this?
press the power button and volume up, volume down at the same time, menu will appear after a few seconds and try resetting the tablet, most likely the OS is corrupted.
Jul 04, 2014 | Tablets & eReaders
Stuck on start up screen
A factory reset may resolve the problem. Detailed instructions are in your manual/operator instructions, but basically you push the hidden reset button when powering up.
Apr 14, 2014 | 7 Google Android 2.2 Capacitive Touch...
My tablet keeps on going back to the loading screen and repeats that
You will need to reset the machine to factory settings by holding in the "Reset" button with the power on. Then just wait until it reboots. If this doesn't work you may need to get the Operating System re-installed.
Feb 18, 2013 | Irulu Black 7 Inch 2gb Mid Google Android...
Philips gogear connect 3 shows only a white screen and its not working
Try resetting your tablet. Google search your make, model and reset. Follow the instructions from one of the results provided.
May 12, 2012 | Philips SA3CNT08K 8 GB GoGear Connect 3...
White screen
May 04, 2012 | Philips SA3CNT16K 16 GB GoGear Connect 3...
Google Nexus 7 Logo
94 people viewed this question
Top Google Tablets & eReaders Experts
NOEL
NOEL
David Payne
David Payne
Are you a Google Tablet and eReader Expert? Answer questions, earn points and help others
