Question about Mitsubishi WD-52528 52" Television
Remote lost cant turn power on because timer set
Black screen red diode blinks
unplug the set for a while then try it
Nov 09, 2013 | Samsung Televison & Video
How to turn the sleep timer off
You obviously don't have a menu button on the set itself. Unplug the unit and remove the back cover, this should expose the info you need unless it was placed on the outside and is now lost. Without TV model it will be difficult to get any helpful assistance. Good luck.
Jul 05, 2009 | Televison & Video
My JVC TV Problem
hi.. sir
if universal remote does not work properly.. i am not sure
just open the tv and see if any cmos battery is inserted .. in circuit board.. if any present.. answer me sir..
Sep 01, 2008 | JVC AV-27D302 27" TV
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
Aug 19, 2008 | Audio Players & Recorders
Remote
the intruction are at the back of the battery .
1 turn on tv
2 press and hold Code Search untill all device bottons light( they will all turn green)
3 press tv button. tv botton will stay on
4 press power repeatedly untill tv turns off
5 press enter and you are all set
repeat 1-5 for vcr , ect
Apr 01, 2008 | RCA RCR350 Remote Control
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Program timer light blinking
The timer light blinks when the AC power has been disconnected and the clock is not set. This is how the set warns you that it can no longer do timer recordings. Setting the clock and doing an autoprogram will fix it, but both the remote and the remote receiver must be working. If the original remote is not damaged and has good batteries in it but does not work on that set and you cannot get any other universal remote to work, then the remote receiver (the IR "eye") inside the set has failed and needs to be replaced. I have seen many of those little receivers failing recently. If you do not have experience changing electronic parts on small PC boards then have a qualified tech change it for you.
Jul 26, 2007 | Panasonic PV-DM2093 Triple Play 20 in....
Mitsubishi WD-52528 52" Television Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
