Question about Dryers
Estate dryer troubleshooting
Electric dryer tedl/tgdl660w will not start. dryer is more than 5 years old.
  • 178 Answers
SOURCE: HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Posted on Mar 18, 2008
docjohn174
  • 943 Answers
SOURCE: estate electric dryer
hi thanks for the question i looked it up and the most likely cause for this problem is the thermal fuse located at the back of the dryer remove back panel and on the air duct you will see a small plastic piece with 2 small blue wires going to it replace this part but also clean all venting to the outside as this will cause this to happen the appliance doc
Posted on Sep 22, 2008
  • 2920 Answers
SOURCE: Estate dryer about 5 years
check the heating element and limit switches if they go bad it will take longer for clothes to dry
Posted on Dec 14, 2008
SOURCE: whirlpool dryer won't heat how can I fix?
Hey, I just read an article online titled, Testing for 240 Volts to Your Dryer - Without a Voltmeter, here's the link http://www.davesrepair.com/DIYhelp/DIY240Vtester.htm
I am not sure how you could test anything else though, such as the thermal fuse or thermostat, without the Volt/Ohm Meter. They are about $10 at any big box home store--we just went ahead and bought one.
Posted on May 31, 2009
localwonder
  • 6784 Answers
SOURCE: electric dryer won't start
HI, check the following to address this issue you are experiencing.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jun 02, 2009
Roper dryer will not start
How to Troubleshoot a Roper Dryer That Will Not Start ' Home Guides ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Jul 14, 2016 | Roper Dryers
Drier is running hot, smells like my clothes are burning, and it keeps blowing the fuse in the main panel.
Most probably a venting problem and probably caused the heating element to ground out in its casing. Easiest way to verify is turn your timer to 30min and if dryer starts heating without pushing the start button you got a bad element caused by bad venting most of the time.
Apr 16, 2013 | Estate TEDX640JQ Electric Dryer
Young dryer quits in mid cycle.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 05, 2010 | Estate EED4300TQ Electric Dryer
Dryer plugged in, but no power
The fuse is located on the rear under the dust cover on the blower housing near the vent pipe. Looks like this: 608d7d9.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 16, 2008 | Estate TEDS840JQ Electric Dryer
Eastate gas dryer 4-5 years old.
if burner does not reignite and glow bar is lighting up suspect the black coils on valve bad
Oct 24, 2008 | Estate TGDS740JQ Gas Dryer
Estate electric dryer
Nov 28, 2007 | Estate TEDS740JQ Electric Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Dryers Logo
21 people viewed this question
Top Dryers Experts
