Question about Home
Replacing my Roman tub faucet
I wanted to replace my Roman tub faucet because the handles continue to leak. They are about 13 years old. Underneath the tub I found copper piping instead of the expected hoses with disconnects. What is the best way for me to proceed?
This might not be a solution but i would recommend you get it done by a professional like i did just make sure u give them all the details before they come so they dont have to go back and forth costing more money as they are per hour basis hope this helps
Posted on Apr 30, 2013
  • 171 Answers
SOURCE: tub spout. Moen
Hi handie Man,
I'm Harvey the Master Plumber.
Your problem is: Just bought a new tube spout to repalce my old one. The new spout same as the old, very common spout.. the inside of the spout has a (white) PVC threaded pipe in it with a smaller tube inside that as a O-ring in it.. You tried to unscrew annoying pipe but it wont budge.. and you dont want to ruin it incase you end up returning it. You think its just a reciver for a 1/2 inch copper pipe (which will fit).
That is exactly what it is. You've purchased a universal spout which requires a 1/2" copper pipe coming out of the wall. If you're not up to changing to that, take the old one to a plumbing supply. If you're lucky they might have a direct replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
  • 10865 Answers
SOURCE: Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
Posted on Jan 21, 2009
  • 62 Answers
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Posted on Jul 11, 2009
  • 62 Answers
SOURCE: I have a 15 year old whirlpool (not necessarily
Sorry. Its not that that easy. You will need to have a plumber advise you onsite
  • 35 Answers
SOURCE: I have a Price Pfister
There could be debris wedge in the cartridge of the faucet. If you have tried pulling the cartridge out to see, and you are still having these issues, more than likely it is a defective cartridge; in which case it should still be under warranty. If you haven't tried this, then I would recommend doing so. Just be sure to turn water off to your faucet first.
Posted on Nov 19, 2009
Copper piping? Tub faucets
1. Measure piping size with tape measure or read printed on pipe. 2. Visit local hardware store and take the faucet. 3. Tell them you need a tubing cutter and sharkbite adapters for the faucet you have. 4. Cut pipe with tubing cutters. 5. Push on sharkbite fittings. 6. Install faucet and supply hoses. 7. Take Bath.
Apr 28, 2013 | Plumbing
Delta T2738 Deck Mount on Jacuzzi Tub. Hot Water side leaking.
With the detailed part number you have, I would just walk into stores like Home Depot or any plumbing store and they will give you the exact parts you need. They are not expensive and a lot of them are standard parts and come in kits.
Good luck.
Apr 08, 2013 | Delta T2738 Lahara Deck-Mount Two-Handle...
Delta foundations windemere roman tub faucet leaking out of spout
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 28, 2013 | Delta BT2796-SS Foundations Windemere...
Set screw is stuck. Any suggestions on how to remove it to replace the roman tub faucet?
to replace the roman tub faucet you have to expose the faucet under the deck of the tub. Most of the time builders do not install a door to do repairs. So expose the underside of the deck of the tub, turn off the main water outside then cut the water pipe for the hot and cold water with a tube cutter. At this point take a sawall and place the blade so the side of the blade touches the bottom side of the deck.
and cut all the way though the body of the stem.
Do all three and your done with the hard part. Install your new faucet and enjoy.
Hope I was help to you Rich
Sep 05, 2011 | Moen T999/4999 Chateau Two Handle Roman...
Dear Sirs, When lifting the handle assembly to use the faucet on model 7100 that has been on the sink for the past thirteen years, the water is leaking from that assembly kit. So the question that I am...
13 years , I would recommend replacing it. You basically got its lifetime out of it.Think re-model, I like to replace mine every 10 years or so.It's time to change the decor. It's actually easier and less frustrating than replacing the diffusor assembly. They are not easy to get off after 13 years & corrosion in inevitable.Your faucet could easily crack or break. You'll actually save time and can avoid a headache doing so.
May 31, 2011 | Plumbing
How do I tighten the faucet handle. The handle is floppy and unless you put downward pressure on the handle when you turn it, it will continue to move from left to right
From what you have described it sounds like the stem in which the handle rests on is stripped and allowing to move from side to side.
Remove handle it has a set screw in the side of it and turn water off. Check the stem may be in need of replacing or the retaining nut that holds the stem down to counter top may be in need of tighting.
Feb 12, 2011 | Kohler Brushed Nickel Roman Bathtub Tub...
Leaky faucet
From the sounds of it. It is time to call in a Pro. Be sure to check references. I hope all goes well.
May 26, 2010 | Grohe Seabury Roman Tub Faucet with...
Moen kitchen faucet leak from spray
This might mean that the diverter in that controls the sprayer needs replacing. It is located behind the valve body underneath the tub spout sleeving
Feb 23, 2010 | Moen ShowHouse S711 Waterhill Single...
Leaking valves in new roman tub faucet installation
take the valves out and check the valve seats use flashlight if they look good then very carefully put your finger in and feel for any burrs when in doubt just replace the seats this is always a good practice when replacing valves
Mar 26, 2009 | Plumbing
Home Logo
156 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
