Question about ASUS WL-330G 802.11g/b (wl330g) Wireless Access Point
FN + F2 did not function in my ASUS laptop.
My laptop is ASUS.  The problem is i want to activate my wireless connection or wifi but when i press FN+F2 it did not function just like the volume key using FN+F10 or F12 is not also functioning.  What will i do?  How these keys will function?
  • 538 Answers
Restart> press F2 on boot = BIOS
Wireless device > ENABLE
Posted on Mar 20, 2009
    New Friend:
Physical Bottom to the left: switch on it.
It is close to usb port.
Enjoy It
Disfruta!
Posted on Jul 30, 2013
SOURCE:
How to turn on wifi? Its been 2 -3 days wifi isnot being loaded?
Press and Hold the FN function key then hit F2 while holding the FN Key down.
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
May 25, 2012 | ASUS Eee PC 1000HE Netbook
Please help me . How do you connect ASUS X58L to wireless so i can use away from home without my router. ?
Hi
Have you enabled your wifi switch or key
and does it show you down in the right hand side of your screen that wireless
networks are available
if it is not enabled then try to press the FN+F2 or FN+F8 or FN+F11 or sometimes
there is a push or slide switch to activate the wifi
Feb 26, 2011 | Computers & Internet
Hello. where exactly is the button on the dell latitude d410 that activates the wifi? thanks.
On Dell laptops usually the wireless is not a hardware switch but a hotkey combination. On most moels (your too I think) it should be Function + F2 to toggle wireless on or off.
Dec 05, 2010 | Computers & Internet
I have bought a brand new asus K52Jr but I cannot connect thru wifi.
Fn+F2 WLAN switch, this function key will on your wireless LAN. Do you have this utility ASUS Wireless Console? If you have, you can check signal or connectivity with wireless connection. Check also your firewall or antivirus settings.
Please rate me!
Nov 23, 2010 | ASUS Computers & Internet
How to switch wireless on
To activate and deactivate the wireless, you have to press and hold down the Fn key while you press the F2 once. If it's already activated, this will turn Off the wireless or if it's deactivated (Off) this will turn it On. This shortcut key is more or less the same on almost all the New Asus Laptops.
Good luck.
Thanks for using FixYa.
Jun 17, 2010 | ASUS Eee PC 900 PC Notebook
I have asus X5DC and cannot find button to turn on wireless
Press "Fn and F2" together and let go and it will show wireless :)
Apr 06, 2010 | Computers & Internet
Why is my wifi not working any were thers a wifi connection
It's possible that your wireless function may be turned off in the BIOS. Try this:
XP:
1. When booting up your Eee PC, press "F2" to enter BIOS setting==>[Advanced]==>[Onboard Device]==>Set "WLAN" as "enable"==>press "F10" to save the setting.
2. Press Fn +F2 to activate the wireless LAN function
When you finish, reboot your pc and try to connect to a wireless connection again.
Good Luck
C2Solutions
Jan 21, 2010 | ASUS Eee 4G Notebook
How to download wifi driver for asus eee pc series
victoria_999 --
Press Fn + F2
"Fn" stands for "function", is located at the bottom-left portion of your keyboard.
If you notice, the color of the wifi icon is different than the letter keys... the color should match the Fn button
This will turn on/off your wireless adapter :)
Hope this helps!
-- RT
PS - Please don't forget to vote!
Sep 05, 2009 | ASUS Eee 4G Notebook
How can active wifi asus eeepc4g
Function (Fn) + F2 will usually toggle wifi on and off on an eeepc.
Apr 15, 2009 | ASUS Eee 4G Notebook
Asus Eee PC wireless connection pending
You may be choosing the wrong encryption method. For instance your entering your wireless key (WEP) and you have it set on (PSA, WPA). Make sure those settings match. Also you may have an IP conflict which is resolved by setting up a static ip. If the encryption methods match and you need help with a static IP let me know
Jan 04, 2009 | ASUS Eee 4G Notebook
ASUS WL-330G 802.11g/b (wl330g) Wireless Access Point Logo
5,433 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
