Question about Dacor Cooktops
82774B Need replacement control knob
Simpson EZISET cooktop control knob does not turn
Take some electronics contact cleaner, CRC is best, and spray the knob. It has grease inside that is preventing the spring from popping it up so it turns. You'll need to get a new knob eventually and please don't install it yourself unless you are well versed in working with gas.
May 08, 2015 | Cooktops
I need to replace two blue indicator lights and I need directions
I have replaced several of the indicator lights in the control knobs.
Turns out that Dacor doesn't sell exact replacement lights (actually LED modules).
What I did was to go to a local electronics supply store and purchase Blue replacement LEDs and a current limiting resistor to connect in series. Replacement LEDs can vary in brightness depending on your taste ... I chose a super bright LED which makes the control knobs noticeably brighter. The value of resistor will vary depending on the LED you choose (brighter LEDs need slightly more current and as such the resistor value will be slightly less).
Once you've opened the range from the top (remove knobs, grates and burners) then remove a few screws and the entire unit opens with a hinge in the back.
Look over the LED light modules which shine just below each knob and fashion a replacement LED assembly.
Total material cost per LED unit was ~ $2-3 (LED, resistor, wire and heat-shrink tubing)
Jan 04, 2011 | Dacor 36 in.PGM365 Gas Cooktop
My husband was trying to help clean the controls and broke off the part that holds the control on the cooktop. Can it be replaced? Help . . . need all four burners for Thanksgiving! DCS CT304
You will have to replace the switch if he broke the shaft the knob was on. you can replace the burners just take the burner to your local parts store and show them what you need. on the switch you will need your model number.
Oct 31, 2009 | Cooktops
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
I ned to replace one of the heat control knobs on
u can find it only in the service center of the brand u have.
Jun 28, 2009 | Cooktops
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
Where in VA do you get replacement rings for DACOR SGM365S burner knobs. These are the rings that go around the control knobs?
Appliance Parts Depot in TX. Look it up. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Dec 01, 2008 | Dacor Preference SGM365SS Gas Cooktop
SWITCH KNOB
Pull off the knob and then see if you can push the shaft in. If you can, then the knob is hitting something, preventing you from being able to push the knob in. Adjust the knob until you can push it in. If you can't push the shaft in with the knob off, then the control valve is broken and you will have to replace it.
Sep 03, 2008 | Miele 35 in. KM326G Gas Cooktop
Viking ceramic cooktop numbers washed off
I have the same problem. The previous suggestions are assanine and have Cleary not actually read the question. The question is how to replace the original heat numbers that rubbed off.
Nov 14, 2007 | Cooktops
Cooktops Logo
53 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
