Philips slc4 HOW TO REPAIR BROKEN CABLE, ANTENNA CONNECTION? MINE HAD BROKEN IN TRANSIT. SHOULD HAVE TAKEN THE CABLE OFF. SNAPPED AT ITS BASE.
    Top Expert:
  • Televison & ... Master
  • 74,666 Answers
It can be repaired. Contact any technician.
Posted on Apr 29, 2013
Can't hear anybody
First, stop transmitting. If your antenna system is compromised, transmitting can cause damage to the output transistors are require an expensive repair to correct.
Carefully check the entire length of the coaxial cable from the rear of the radio to the base of the antenna. Pay attention to pinch points between body panels, door openings, etc. Crushed coaxial cable results in a short circuit and must be replaced. Chafed or an otherwise damaged outer jacket on the coaxial cable will allow water to enter and contaminate the dielectric and oxidize copper braid and center conductors. This type of damage requires replacement, too.
Inspect the connector at the radio. Make sure that the soldered joints in the connector are still secured and have not broken and caused an open circuit or short circuit. This connector should be snugged up hand tight to the radio's connector.
Check the feed point of the antenna. This connection is often subject to moisture and can oxidize quickly. Look for evidence of oxidation and other open or short circuit conditions here. Cut the coax back until all the oxidized cable is not longer visible and reconnect to the antenna feed point. If possible, coat this connection completely in a thin coating of silicone to keep water from attacking the connections or entering the coaxial cable.
Check any connections between the antenna base and the antenna itself. Many antennas allow for removal for car washes, etc. by unscrewing / quick disconnect from the base. Clean threads or retaining pins on both the base and antenna thoroughly. Check the center pin contacts on the base and antenna for evidence of good contact. Oxidized surfaces here can indicate a poor connection. Clean or replace as needed.
Make sure that the surface to which the antenna is secured (tool box) is solidly grounded. One or more large conductor bonding jumpers from grounded vehicle panels, frame, etc should be extended to the tool box. A tool box that merely sits on / bolted to the truck's bed is probably not providing enough contact with unpainted, grounded body panels to provide sufficient ground for the antenna system to work well.
Check the tuning slug at the end of many fiberglass antennas. It should be present, and have the protective cover to seal out the entry of water.
Lastly, after the above has been addressed & corrected, tune the antenna to the radio on the truck with a quality SWR meter for the frequency range of the CB as per instructions.
I hope this helps & good luck!
Apr 16, 2012 | Cobra 19 DX IV CB Radio
How do you fix a snapped off antenna on a kia soul
@womonsoft7 I'm giddy with childish excitement because this actually worked for me "If you're lucky, you can sometimes just push a screwdriver against the edge of the screw and rotate the screw out that way". After reading this I thought it would be worth a try...It just happened to be loose enough for this to work. My Antenna was broken off by a low clearance garage door, actually thought I smashed in the roof, but it was just the antenna. Easiest fix imaginable.
Jan 07, 2012 | 2010 Kia Soul
Poor radio reception.I've tried a new aerial mast,no improvement. CD player sounds fine. Any ideas? (Passat Est.2003)
Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 1 Subject: Model(s): Group: Number: Date: AM Radio, Poor Reception 1999, 2000 91 99--07 New Golf, New Jetta, Aug. 2, 1999 New Beetle, Passat Condition AM reception is poor. May be caused by: ? An incorrect antenna mast installed for the antenna base equipped with the vehicle ? Poor ground at the antenna base or radio ? Poor battery ground to chassis or engine ? Poor antenna cable connection at Radio ? Corrosion at the antenna coaxial connectors at radio or antenna Service Vehicles are equipped with either a Bosch or a Clarion antenna base mounted on the roof and (for shipping purposes) the appropriate matching mast is located in the luggage compartment. If radio antenna masts are removed from vehicles and stored until vehicles are sold, there is a chance that an incorrect mast can be installed at the time of delivery. Note: Mismatched antenna mast and base will cause poor AM radio reception. The antenna base and mast can be identified visually as follows: (Cont. on Page 2)91-A260 requires gloss finish antenna mast 57mm 49mm Bosch 91-A261 requires matte finish antenna mast 61mm 41mm Clarion 91-A262 Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 2 Bosch antenna ? Base (although oval) is more circular in shape (approx. 57mm x 49mm). ? Made in Germany stamped on underside of base. ? Two screws on underside of base are unpainted. ? Requires gloss finish antenna mast. Clarion antenna ? Base is more oval in shape than Bosch (approx. 61mm x 41mm). ? Two screws on underside of base are painted. ? Requires matte finish antenna mast. If antenna mast matches the antenna base correctly: -- Check antenna coaxial cable connections --arrows-- for corrosion and clean if necessary (DO NOT apply stabilant). Passat coaxial cable connection for radio is under the carpet on right side of tunnel near shifter. -- Ensure that coaxial cable is firmly seated in radio (Passat cable connection, see previous step). -- Check ground at the antenna below roof Nut --4-- (torque = 7+1 Nm) must firmly secure antenna to roof). (Cont. on Page 3)Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 3 -- Check ground for radio behind radio on cross member (On Passat models as of Nov. 1998 beginning VIN: XE285000 ground for radio is on right side of center tunnel). -- Check engine compartment ground, left side, below battery tray; frombattery GND to body. -- Check engine/transmission ground on transmission, near engine block. -- If all grounds and antenna mast are OK. -- Replace antenna and coaxial cable assembly
May 06, 2011 | Car Audio & Video
Coax connector is broken off-how can i replace the connector?
You can pick up a chassis mount F connector here...you will need someone with basic soldering skills to replace:
http://www.electronix.com/rca-connector-p-13010.html
Oct 21, 2010 | Samsung TXG2548 TV
Where can you purchase a replacement antenna for
I just replaced my broken antenna for my CFD-S350 by calling Sony Parts and Support at (239) 768-7691. Cost only $7.99 and that included the $2.00 shipping charge.
Jun 03, 2010 | Sony CFD-S350 Radio/Cassette/CD Boombox
Broken antenna - 1996 oldsmoblie ciera
I assume it is an extendable antenna, if so loosen the ring around the antenna base there are usually like 4 slots on it, after you have removed the ring, have some one turn your car to the accessory mode and turn the radio on, your antenna or what is left should come right out, to install your new one just feed cable down hole and have them turn your radio off you may need to spin the antenna just a touch to let it catch cable, be sure to put your antenna ring back on.
May 27, 2009 | 1996 Oldsmobile Cutlass Ciera
Grundig YB400PE broken antenna
Unfortunately, your description of the problem means that your radio must be taken apart to be fixed. Replacement antennas can be found purchased. It would require installing the new antenna and most likely soldering it to the broken wire. Do you have a picture?
Apr 05, 2009 | Grundig YB 400PE AM/FM/SW Radio
2007 Ford Focus how to replace broken antenna
it unsrews
Antenna Base Removal
  1. Remove the antenna mast from the base.
unscrw counterclocwise
  1. Detach the interior light.
  1. Remove the interior lamp.
    • Disconnect the interior light electrical connector.
  1. Remove the interior lamp bezel.
  1. Remove the antenna cable/base retaining screw.
  1. Remove the antenna base.
Mar 14, 2009 | 2007 Ford Focus
Broken antenna
It is not Very Easy to get to But, You can access this through the Fender Holes under the Hood. Please Rate My Response! Thanks!
Feb 05, 2009 | 2002 GMC Yukon XL
1989 oldsmobile cutlass ciera 3.3L V6 power antenna broken
You need to access from outside the vehicle. You have to remove the shroud that is inside of the wheel well. It is not a very easy task I hope this helps.
Feb 04, 2009 | 1989 Oldsmobile Cutlass Ciera
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
