Question about Dryers
GE Profile Dryer stops running after multiple loads
I have a dpvh880ej GE Dryer (electric). I have no problems if I run the machine on a daily basis. On the weekend, when the laundry has piled up, the dryer fails to adequately dry the clothes after multiple loads. After we find the clothes to be damp (or wet), we start another cycle. The dryer will run for a few minutes and stop before the cycle is completed. This can be either under a 'timed' cycle or a 'moisture sensor' cycle. If we wait long enough (say, overnight), it runs fine the next day. I'm reluctant to call a repairman at this point because not only can I not duplicate the problem on demand, but I won't be able to see if it's actually been fixed until long after the repairman has gone. Something seems to be overheating, and then when it cools down behaves correctly. Any ideas, and can this be fixed on a dyi basis? I can perform basic repairs, but I'm not going to want to have to dissect the machine and put it back together.
Vish2
  • 74 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Posted on Oct 11, 2007
maklean
  • 1665 Answers
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Dryer - sensor problem
When I pull up the exploded view of your model, it does not show an individual moisture sensor, but is does show disconnect plug(s) for it. I can only assume that the sensor bars are an intrical part of one of the front bulkhead components. That all being said, the most common reason for your symptoms is when people use fabric softener sheets in the dryer, the sheets leave a waxy type coating on the silver sensor bars inside the drum, near the air inlet to the lint filter. If you clean those two (usually about 4 inch long x about 1/4 inch wide) metal bars off, they will be able to detect the moisture level of the clothing again, and your dryer will work on auto dry again.
Posted on Jan 24, 2009
SOURCE: DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Posted on Mar 28, 2009
  • 10 Answers
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Posted on Jun 02, 2009
Runs but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Dec 22, 2009 | GE Profile Harmony DPGT750EC Electric...
My GE profile WPDH8800J doesn't hit high speed
Your belt may be slipping and not spinning the drum to full speed to rid most of the water in clothes.
Sep 09, 2017 | General Electric WPDH8800J Front Load...
Our ge profile electric dryer has recently started to make a screaching sound while it is running
Your problem sounds like drum rollers is in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 13, 2009 | GE Profile Harmony DPGT750EC Electric...
My GE Electric Dryer model GEQ9858JQ0 will not stay running; can restart and will run again but will stop again multiple times before cycle is complete.
Have you cleaned out the lint filter and the exhaust hose, it's got to be cleaned out to allow air to exit. This will trip the high temp limit.
Jul 23, 2009 | Dryers
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
Jan 24, 2009 | GE Profile DPSB620ECWW Electric Dryer
GE DRYER STOP RUNNING
sounds as if the belt has snaped and the drum has droped stopping you moving the drum
Dec 05, 2007 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
44 people viewed this question
Top Dryers Experts
