Murray riding lawnmower motor scamatic
I need a copy of motor for model # 809029x92b serial # 7495609433q336
  • 24 Answers
SOURCE: murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
Posted on Feb 08, 2009
mowerman1857
  • 389 Answers
SOURCE: need wiring diagram for 11 hp murray riding molwer
http://www.partsandservice.com/db/pl/Murray/38618x92e.06.gif
Here is a link that will take you straight to the diagram you need
Posted on Oct 02, 2009
Testimonial: "Perfect. just what I needed Thanks"
mowerman1857
  • 389 Answers
SOURCE: murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Posted on Oct 04, 2009
SOURCE: murray 21 inch 3.75 lawnmower. Not starting.
buy a ethanol based spray called start ya bastard. spray in the carburator and then pull the cord. 9 out of ten it will start
Posted on Mar 15, 2010
  • 35 Answers
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
Posted on May 09, 2010
I am seeking a service manual for a Murray ride on mower Model 405600X50B
Find a customer service number for Murry. Most likely they will
need model and Serial number. Probably will send you a replacement if your "nice about it".
Feb 27, 2015 | Murray Garden
I am looking for manual on Murray ride-on lawnmower, model no.42587X50C.
Murray is made by MTD on the site you can get the PDF of the manual for download. I have it
Apr 19, 2013 | Murray Garden
Motor runs fine but can't go foward or backwards on Murray 8hp rear engine riding lawnmower
check the drive belt it might have broke or fell off a pulley
Apr 27, 2012 | Garden
I am looking for a belt placement diagram for a 42" murray riding mower-drive belt.
Use your model number & go online for Murray Riding Lawnmower & search. Most of the time you will find it. If not reply back with model numner & HP (horse power)
Aug 03, 2010 | Garden
I am looking for an owner's manual for a Murray riding lawnmower. It is a Select 1, Model Number 309804 X8E, Serial Number 74565143Z4D714. I have tried to find this on the internet with no results. There...
If you go to http://partsandservice.ca/, and click the Illustrated Parts Catalogues link, and then use the interactive selector, you may be presented with individual pages of the manual you are looking for.
Jul 14, 2010 | Sears Garden
I need a diagram for a drive belt for a murray lawnmower
Locate your model number and serial number off the tag under the seat,
GO TO; www.murray.com/manuals/index.cfm?rd=1
Type in your model number and an owners manual/parts manual will download. There will be a diagram in there for drive belt, blade belt and a ton of other useful information
Hope this helps you out
Oct 08, 2009 | Briggs & Stratton Garden
Murray 42'' riding lawnmower owners manual
www.murray.com
Oct 04, 2009 | Garden
I need a part no for a murray lawnmower model no.7-39004
The belt number is 37x26. As for a diagram, I have it on micro fiche, but can't find it online. I wouldn't want to try to put that one on. lol I'll see if I can get a copy and e-mail it to you. I have the belt if you can't find it locally.
Jun 26, 2009 | Garden
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
