Question about Garden
On a Sears craftsman lawn tractor model # 917.252540, how do connect the torison spring part#140086 from the arm assembly part #131845 to the mower housing?
wadembly
  • 489 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
wadembly
  • 489 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
  • 138 Answers
SOURCE: how do i replace the lift shaft assembly on my
there is not enough space here to describe the replacement procedure. some helpful tips though - order the part you are replacing [ordering from sears tell them: division 71, source 917, part no. 159471] before you tear into it. sitting around for 3 or 4 weeks, you'll probably forget where things attach. also, find the exploded parts diagram in your owner's manual and look it over carefully to see what you're getting yourself into. sometimes, it's worth a few bucks to let a competent shop do the work
Posted on Aug 17, 2009
  • 3 Answers
SOURCE: Need image, assembled craftsman model 917.276813 lawn mower deck
http://afternoon-tea.bordadom.vu.cx/index.html italian wine bar
[url=http://afternoon-tea.bordadom.vu.cx/index.html]italian wine bar[/url]
<a href=http://afternoon-tea.bordadom.vu.cx/index.html>italian wine bar</a>
Posted on Aug 26, 2009
I have a craftsman lawn tractor having problem with spring extn. 732046168. Tractor model 247288851. the spring is connected to idler bracket bracket assembly.
Howard, possibly the wrong spring # not matching as parts diagram in links below, do you have the old spring to sort of match it up or are you possibly putting it in the wrong retaining hole. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http www searspartsdirect com model part 247288851 0247 1509200 1106099p...
http://www.searspartsdirect.com/partsdirect/user-manuals/247288851-craftsman-tractor-manual
http://www.repairclinic.com/Shop-For-Parts/a21b317d1124318/Model-247288851-Craftsman-Lawn-Mower-Parts
No Need to see diagram of the springs that are on the deck of riding mower...
Jun 10, 2016 | Craftsman Garden
Replacing a mower brake tension spring
Mower Brake Return Spring Replacement - Craftsman ...
? 2:15
www.youtube.com/watch?v=kyuE5NBR5xU
Jul 31, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing abrake return spring on Craftsman riding lawn ...
Oct 27, 2015 | Craftsman Garden
I need to replace springs on mower deck of a craftsman LT1000 does sears carry replacement springs or can i go somewhere else
if you have the parts to the old one you can match it up at a hardware store but try sears online www.searsparts.com but shipping will be as much as the part
May 20, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to install clutch in craftsman lt 1000
there is no clutch,, you have an arm with a pulley that is spring loaded .. when u release the " clutch" this arm pulls a pulley against the belt taking up the slack ,, make sure the belt is not worn ,, or the spring is broken or loose
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where does the manual clutch cable mower deck spring connect to on a Craftsman YS4500?
It should connect on top of the idler pulley on the idler arm. The bolt is extended and the spring hooks over it with a 'hairpin' or cotter key through the hole in the end to hold it on.
Oct 09, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Mowing deck pullies, mounting and spring application.
Download the product manual from the Sears website. Murray manufactured these tractors so you can download the manual from the Murray website also. Procedure for replacing the mower deck belt is quite simple. No need to remove the deck. Spring location also on diagrams. Mower deck parts diagram breaks down the whole assembly. Easier way to remove pulleys is using an impact wrench, otherwise hold the blade while removig the nut that holds the pulley in place. Use a heavy glove to hold the blade for safety!
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Model 40601B riding lawn mower-need tension pulley spring
Your owner's manual has a parts breakdown with all parts listed. Find the part # and order from local Sears store. No manual? Try the Murray website (www.Murray.com) and download the manual for model 425001x8D lawn tractor. Good luck!
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
180 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
