Question about Flotec FP3222 3-Wire 4-Inch Submersible Well Pump - 3/4 HP, 10GPM
Flotec water pump wiring diagram - Flotec FP3222 3-Wire 4-Inch Submersible Well Pump - 3/4 HP, 10GPM
4 Suggested Answers
  • 969 Answers
SOURCE: Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Posted on Apr 30, 2009
  • 142 Answers
SOURCE: 3/4 pump -is pumping water - but a a slow pace
Re prime the pump. Make sure the suction line is completly flooded so it will take a good suction from the well.
Posted on Jun 03, 2009
john224
  • 1378 Answers
SOURCE: Flotec pump problem
Thank you for posting your question here on Fixya.com.
No, only a thermal overload. If the unit was hot and has had a chance to cool off it should start. If you have voltage to the motor and it will not even hum or buzz, you need a new motor. The short must have blown the winding open.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 28, 2010
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Aug 30, 2015 | Flotec Pump FP4022-10
Wiring diagram
??? THIS PUMP COMES COMPLETE WITH A THREE PRONG GROUNDED PLUG ON IT'S END , NOT SURE WHAT YOU MEAN BY "WIRING DIAGRAM" IT JUST PLUGS IN LIKE ANY OTHER APPLIANCE DOES
May 20, 2015 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
I thought I remembered how to wire a flotec 5182 pump, but obviously not. I put a new impeller kit into it and now it just clicks when I turn it on. The manual and the diagram on the pump are unclear. The...
try www.freeadjunction.com>wiring>wiring-dia
I found that site by going google and typing---schematic diagram for wiring a flotec 5182 pump
there are other sites if that is not suitable
Nov 18, 2017 | Flotec Pool & Spa
STORES THAT SELL FLOTEC 1/3 HP MODEL NO. FPSC2200A-08 115 VOLT 60 HZ 9AMP SUBMERSIBLE PUMPS
Your best bet is to get off this site, go to Google or Yahoo or any other search engine and type in "Flotec Pumps" and you will get several thousand places to shop.
Aug 03, 2012 | Flotec Plumbing
Flotec 1800A SUMP PUMP located in a pit in the middle of a concrete pad. I Cut the plug off the float to get the wire to fit thru a 1.5" PVC pipe (the same size used for discharge). It is...
when you are trying to connect a 2 wire system into a 3 wire system sometimes it just won't work.
try keeping your black/black and change the white with the 3rd wire if that fails try white/white and the black with the 3rd wire.
without a wiring diagram it is hard to tell what each wire is for, and like I first said sometimes these systems cannot be mixed
good luck
Aug 23, 2011 | Flotec Corrosion Resistant Shallow Well...
I have a 3/4 hp Flotec 4022 pump. Prior to that I had a goulds 1 hp pump on the same 120 circuit with no issues. The Goulds pump housing started to go so I replaced it. Since replacing it with the Flotec I...
Hi Eglenni,
Here are the specs for your pump:
Thermoplastic Shallow Well Jet Pump 3/4 HP. This new revision of an "old hand" provides good pressure pumping from wells where the depth-to-water is 25' or less.
BODY CONSTRUCTION: Thermoplastic
HORSEPOWER: 3/4
MAXIMUM CAPACITY: 12 GPM
FLOW at 10' LIFT and 40 PSI: 9.7 GPM
MAX LIFT: 25'
MAXIMUM PRESSURE: 78 psi
PRESSURE SWITCH SETTING: 30/50
SUCTION PIPE SIZE: 1-1/4" NPT
DISCHARGE PIPE SIZE: 1" NPT
AMP DRAW (full load): 6.1 amps on 230v / 12.2 amps on 115v
VOLTAGE: 230v / 115v, 60 Hz
RECOMMENDED BREAKER: 15 amp on 230v / 20 amp on 115v
MAXIMUM WATER TEMPERATURE: 140 °F (60 °C)
Note that this pump can be operated at 115 volts or 230 volts (A/C) It may have come wired for 230 volt use from the vendor.
Make sure the pump is piped correctly.
There should be a wiring diagram either on the pump or in the literature so you can check to see how the pump is wired.
MAKE SURE
you have the pump wired for 115 volt use in your case. Also make sure the wire size is #12 awg for the power wiring.
Make sure all connections are tight. If you have an amprobe (an instrument that measures electric current) you can check to see how many amps the pump is pulling when it runs.
You said your old pump was 1 HP. This Flotec pump is 3/4 horse so there could be some pump performance loss depending on the well depth and length of the piping runs.
Here's the link to the website for the pump. There are additional resources available on the website:
Thermoplastic Shallow Well Jet Pump 3 4 HP
Jul 05, 2017 | Northern Tool Electrical Supplies
I need a wiring diagram for a 1/2 HP 220V flotec water pump please. Can't find one any where.
Here you go hope it helps Tim:
http://www.depcopump.com/datasheets/flotec/FP2100_series,FP2200_series,FP3100_series,FP3200_series,FP3300_series_manual.pdf
May 27, 2011 | Home
How do i prime a flotec electrical well pump.
remove plug in top of pump or plumbing. fill with water u may have 2 repeat sev. times
Dec 05, 2009 | Flotec Plumbing
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Jan 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Flotec FP3222 3-Wire 4-Inch Submersible Well Pump - 3/4 HP, 10GPM Logo
50 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
john h
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
