Question about Whirlpool 3LCHW9100WQ SEMI-PRO FRONT LOAD WASHER FOR 220 VOLTS
How do I fix a F26 error on my whirpool semi pro washer?
3 Suggested Answers
  • 98 Answers
SOURCE: Washer Error code
http://www.applianceaid.com/frigidaire_frontload_washer5.html
click the above link and check out for your problem.
thanks.
Posted on Oct 12, 2008
  • 1382 Answers
SOURCE: whirpool duet washer - error code f35. shuts off
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Posted on Jul 27, 2010
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
Screen is saying out of order f26
Front bottom panel ( under ) door is removed to expose pump clean out access points lint , loose change, tooth picks Exeter. Also attached ither to top, front bottom or rear access pannel is a electrical schematic with decoder and test guide.... please do not attempt with out tools and electro mechanical experience .especially if under warranty . Ie call for service if in over your head...
Nov 05, 2014 | Whirlpool 3LCHW9100WQ SEMI-PRO FRONT LOAD...
My Whirlpool semi pro washer was displaying a F26 error code. So, I attempted to clear it by opening and closing the door, as the manual instructs. Since that didn't work, I entered the service access...
Hi, What is the model number of the unit your working on? If you can get into service mode, are you able to factory reset the unit? Most of the time this would correct any miss entered and changed programs. I need more information to direct you correctly. Looking forward in assisting you if you still need it.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 03, 2014 | Washing Machines
Whirlpool 3LCHW9100WQ Semi-Professional 9kg Washing Machine
Possible fault with the door switch or the control panel but you can try to open and close the door few times to reset after removing power.
click this link: error code F26
Oct 03, 2013 | Washing Machines
My maytag commercial washer display a code F26
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Washer says f26 and won`t spin the clothes out. is there anything i can do?
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
I have an F26 code and my washer won't do anything and cannot find code in the manual what does it mean? It's a whirlpool duet ht
Hi, This F26 error means "door switch error" If the door has not been opened for three consecutive cycles or the door switch is open while the door is locked for more than 5 seconds
Do the following to fix the problem:
Verify CCU operation by running a Diagnostic test or any cycle
Push the door and check if its completely closed
Apr 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does F26 mean
Hi, Well The error F26 does indicate a fault in the door switch circuit. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close.This is most likely a problem with the door switch or a loose connection at the switch.
One thing to try first before scheduling service or replacing the part is to check the connections on the door switch.
You can unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
Thanks! mannu_rakesh
Sep 11, 2009 | Washing Machines
Whirlpool 3LCHW9100WQ SEMI-PRO FRONT LOAD WASHER FOR 220 VOLTS Logo
46 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
