Question about Miele Red Star Bagged Canister Vacuum
Cord winder not working
My vacuum would not turn on because the cord winder had slipped and the electrical connection was not complete. I took the winder apart and repositioned it and then it would turn on, but the cord did not wind all of the way up. When I re-wound the cord so that it was cocked to pull the cord all of the way in, but then the spring exploded out. I keep re-winding the spring but it keeps slipping. Have I lost a part or am I missing a step in my reassembly?
  • Anonymous May 22, 2008
    hi & thanks the cord only comes out about 2 metres then gets stuck internally . i can't figure out how to pull it apart to fix the jammed cord , or reel problem.
    it's a miele electronic s291 air clean plus type hs03
    any clues would be appreciated dave s
    President:
  • 1,673 Answers
Most times you will have to replace the cord rewind. Sometimes just the cord, but usually there is a problem with thr reel contacts. But now that the spring has unwound, you will have to replace it. You will need model number rather then Red Star.
Posted on Feb 22, 2008
SOURCE:
How to replace electolux 7000 cord
These canisters are not easy to change the cord in. If you're somewhat handy and know how to disassemble the machine, it is more cost effective to just order a cord winder complete assembly and switch them out yourself! It's most likely less expensive than the labor and parts you'd pay to have it completed! I have them! Hope it helps! Thanks!
Aug 26, 2014 | Electrolux Vacuums
Electrolux vacuum ergospace stop working how to fix
I am not too familiar with this particular model but I would think the cord winder may be shorting out. I think you can take it apart by turning it on its side, pull the side strips off. It is a bit tricky but if you access the winder check the electrical conitinuity from the winder to the plug in cord. You are probably better to take it in but if you cant please be careful to not get a shock..
Jan 16, 2014 | Electrolux EL4100A Ergospace Cannister...
The cord will not rewind
These get stuck all the time...I own 2 of these , and I have done this many times...Get a can of WD40 or some type of spray lubricant with the little straw in the nozzle. Try pulling and pushing the cord back inside(don't pull it too hard) while you are spraying the lubricant directly inside where the cord comes out. push the cord back in as if you were going to force all of it back inside the cord winder. You may even have to bump the back of the machine where the cord winder is located. But it will wind back up.If you are worried about getting the lubricant on something that it doesn't need to be on , then take the Vac apart and spray it directly on the the coils of the cord winder..A lot of times, that's all they do in the repair shop when they tell you they replaced the cord winder....
Jun 15, 2011 | Electrolux Epic 6500 Vacuum
I have an Electrolux Guardian Canister vacuum. The power cord was damaged but the cord winder still works fine. I have ordered a replacement cord and need to know how to remove the old cord and install...
I strongly suggest allowing a qualified service tech at an authorized Aerus Electrolux store take care of this. The disassembly and reassembly of the tank and cordwinder are tricky and complicated and incorrect reassembly can cause serious problems. Even to the extent of permanently damaging your vacuum, or worse, result in a shock hazard or fire.
May 24, 2011 | Electrolux Guardian Bagged Canister Vacuum
We bought a new cord winder for our Electrolux 1205 Canister Vacuum cleaner and we are trying to install it is not turning on. We get it all connected but it doesn't turn on. Is there a reset button or...
Did you put a bag in the vacuum?
I suspect there's an improper wire connection somewhere, but there are other things that could cause this I strongly recommend taking it to an authorized Aerus Electrolux dealer and letting a trained tech check it out.
http://www.aerushome.com/storelocator/
Mar 21, 2011 | Electrolux Vacuums
My Miele Carina Vacuum stopped working. Does it have a fuse that can be replaced that could be at fault here?
although it might have an internal fuse on this model, I dont think that will be the problem.
The miele cord rewinder has been known to have a small fault in it where the cord winder that actually retracts the cord onto will come apart from the electrical connection in the cord winder itself.
As most of these units have a 5 year warranty anyway, I suggest that you take it to your nearest miele dealer for a repair/replacement on the cord rewinder.
Good luck.
Nov 06, 2010 | Miele Carina Vacuum Vacuum
Miele just stopped working?
When a Miele canister just stops working all of a sudden, it's usually a pretty clear indication that either you have a bad cord reel, or a bad switch. I would say that in 60% of Miele repairs that I do with this problem, the cord reel has gone bad.
One easy thing that you can try to see if the cord is bad, is put one hand on the on/off switch, and the other hand grab the cord (making sure it's fully retracted inside the canister). Now pull the cord out slowly with your one hand, while continously turning the switch on / off, on / off. Keep pressing the switch on and off while pulling on the cord. Usually if the cord reel has gone bad, then you may hear the vacuum attempt to start, or even turn on while you're pulling on the cord. The cord reels in Miele use a metal spring inside that makes connection with the rest of the vacuum. Over time this spring will start to loose it's strength, and eventually will get so bad that it no longer makes contact with the rest of the vacuum. By pulling the cord out slowly and pressing the on / off switch, a lot of the times the spring will make connection somewhere, and the motor may turn on temporarily.
If this happens, this indicates your cord reel needs to be replaced. I have done a detailed repair here on Fixya on how to replace the cord on a Miele canister vacuum that you may read here;
http://www.fixya.com/support/t2281026-miele_s514_will_not_come
If you can't get the vacuum to turn on at all, this can only mean a few things. First the cord reels spring is gone completely, and wont make any connection with the rest of the vacuum, and you'll still need to replace it.
It also can mean that just the plug that plugs into the wall is bad, is your plug bent, or no longer straight on either prong?
It can also mean that your motor has gone bad. This however is usually the least likely of all the problems. The Miele motors are almost bullet proof, and typically last 20 years. I can count on one hand the number of Miele motor replacements I've ever done in 10 years of fixing vacuums.
I can try and help you diagnosis this further if my suggestions didn't help you. Please use the clarification request that you see here on this page to ask me a question. Please just let me know what happened when you tested the cord out as I suggested above. I really hope this was helpful to you. If you found this to be helpful, please be sure to rate the repair as helpful to you by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele S318 Bagged Canister Vacuum
Electrolux el6985 cord brake does not hold how do
you have to replace the cord winder. Since eureka bought out electrolux their product quality has really went down the drain.
Jan 02, 2010 | Electrolux Harmony Canister Vacuum -...
Have a miele S546 vac. and it won't turn on. Is there a fuse? Can the on/off switch burn out? Thanks.
If you vacuum wont turn on it is most likely the cord winder. This is a pretty big repair, you wouldn't want to attempt it yourself. Most shops should be able to repair the cord winder for about $50-75. If you need a new cord winder expect to pay about $150.
Oct 13, 2009 | Miele S548 Bagged Canister Vacuum
Vacuum not running; do I have to replace the cord winder or just cord?
Typically, the cord and winder are supplied as a unit.  It is possible to fit new cord to an existing winder, but the amount of labour involved will make the job more expensive than simply exchanging the complete unit.  Even if you're going to do the job yourself, it's simply not worth planning to just fit new cable (unless you are a masochist with unlimited time and patience).  Pay that bit extra for a complete unit - you'll be glad you did (or you'll be sorry if you don't!).
May 27, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Miele Red Star Bagged Canister Vacuum Logo
1,079 people viewed this question
Top Miele Vacuums Experts
Colin Stickland
Colin Stickland
Gerry Harvey
Gerry Harvey
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
