Question about Juicers
How to thread up the acme rxm-77-a?
My acme coverstitch is skiping the thread bust it's not stitching
I have an acme juicerator 6001 model and I was just juicing... i put vegetables in before it was quite warmed up and it looks like something happened to the motor. Is there a way to fix this?
You may have tripped the reset button on the bottom of the juicer, just push
it back in. They really don't have to warm up, just give it a few seconds to reach
speed.
Apr 21, 2011 | Acme 5001 Supreme Juicerator Juice...
Are the parts for my acme 11je45 the same as those for the acme 5001 and the 6001?
I have a 11je45 also, circa 1990. The only problem I had was replacing the cover.
The plastic covers for the newer Acme's will not fit unless you file the ridge down
where it fits into the juice bowl. Its a pain, but can be done. The other parts, like
the clutch nut, shredder blade, etc., should be the same. No supplier, I gooled,
says they have the older covers, but I know they are out there because I got one
when I ordered the newer version. They seem to be unaware they have them.
Mar 06, 2011 | Acme 6001 Juice Extractor
I am looking for parts for the Acme 6001 Juice
Just google Acme juicer parts. The new lids are a tight fit and
have to be filed down if you're handy.
May 11, 2010 | Acme 6001 Juice Extractor
Acme juicer vibrating so much.
I've had one for 21 years and when I replaced the blade the same thing happened.
The blade is not supposed to be held firmly in place so it can slip intentionally to
minimize vibration. If you bought the juicer new, think back, and I believe you will
remember the vibration problem. I seems with a worn blade they vibrate less. The
motor is very durable and uses roller bearings like on a skate board. I went back
to the old blade, which I sharpen with a drill using a small bit.
Jan 11, 2010 | Acme 6001 Juice Extractor
Looking for an acme juicer manual
YOU CAN VIEW THE MANUAL ONLINE AT
WARINGPRODUCTS.COM. IT MAY NOT HELP
IF ATTACHMENT IS BUSTED. TRY TWISTING
THE SPINDLE TO SEE IF GEARS ARE
WORKING.
Jan 01, 2009 | Acme 6001 Juice Extractor
Acme 6001 / 5001 manual
GO TO WARINGPRODUCTS.COM AND VIEW
THE MANUAL FOR THEIR NEW JUICERS.
THEY ARE THE SAME AS OLDER ACME'S
Jul 23, 2008 | Acme 6001 Juice Extractor
Where can we locate a parts store?
The cutting blade can be found at http://www.waringproducts.com/ret/.  Waring now makes the juicers.  Good luck!
Mar 11, 2008 | Juicers
Juicers Logo
Top Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
