Question about Sanyo Split System Air Conditioner
Clean the blower wheel on a Sanyo ks2472 - Sanyo Split System Air Conditioner
2 Suggested Answers
tunerprobe94
  • 26 Answers
SOURCE: need a remote control for a Sanyo model # KS2472
most times you can contact the company. if that doesnt help, try ebay
Posted on May 24, 2012
Have a Sanyo KS2472 split inverter unit. On turning it on, operation light blinks and does not cool. Also compressor does not seem like it turns on outside. Please help.
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
Jun 06, 2015 | Sanyo Heating & Cooling
Sanyo stw1525c2 packaged terminal unit I am
All available parts are discontinued. Troll for another used parts unit online like craigslist
Sep 26, 2013 | Sanyo 18KS52 Air Conditioner
I need to remove and clean furnace blower.
The entire blower and housing slides out you should find the mounting screws on each side of the blower housing they may be sheet metal screws either on the top or on the bottom. After you remove the two screws the blower should slide out. If you remove the blower wheel from the shaft make sure to tighten the lock screw on the flat side of the shaft. Another trick to pull the blower wheel from the shaft is loosen the lock screw and push the wheel in then clean the shaft wit fine sandpaper otherwise you can cause the wheel to jam up because dirt gets stuck between the wheel and the shaft
Oct 23, 2012 | Heating & Cooling
Need a remote control for a Sanyo model # KS2472
May 24, 2012 | Sanyo KS2472 Indoor Wall Mounted Air...
How to Replace a Blower Fan in an Excursion
Blower Motor
See pics bellow Removal
  1. Disconnect the electrical connector from the vacuum pump (7.3L diesel engine).
  1. Remove the bolts (7.3L diesel engine).
  1. Disconnect the vacuum hose and remove the vacuum pump and mounting bracket (7.3L diesel engine).
  1. Disconnect the speed control servo connector (5.4L and 6.8L gasoline engines).
  1. Remove the bolts and remove the speed control servo (5.4L and 6.8L gasoline engines).
  1. Disconnect the connector.
  1. Remove the blower motor ventilation tube.
  1. syo%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: Carefully remove the blower motor so as not to damage the wheel.
    Remove the screws and remove the blower motor.
  1. syo%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: If the wheel is to be reused, clean the corrosion from the shaft end prior to removing the wheel.
    Remove the wheel from the blower motor.
    1. Remove the push clip.
    1. Remove the wheel from the blower motor
5_7_2012_2_47_23_am.jpg2
5_7_2012_2_48_41_am.jpg3
5_7_2012_2_49_22_am.jpg4
5
6
7
8
9
Installation
  1. Follow the removal procedure in reverse order.
Jan 11, 2012 | 2000 Ford Excursion
I have a sanyo split system and one of the inside units creates ice around the coils. the filters are clean and there's nothing blocking the air around it. What can it be?
There are reasons for.
1. Dusty indoor coil and blower wheel - Clean it.
2. Less speed of blower motor- Replace capacitor/motor
3. Short of gas- Find leak and rectify.
Thanks.
Jun 29, 2011 | Sanyo Split System Air Conditioner
My husband cleaned the dryer vent with a brush today and now it is so loud and vibrating. It is a Neptune bought in 1999
Some lint found its way back into the dryer and is caught up in the blower wheel,the speed at which these blower wheels turn any trash that gets hung up will cause a vibration and noise.You are probably going to have to remove the front panel and blower wheel cover to get access to the wheel to clean it out properly. Its fairly easy BUT FIRST UNPLUG THE DRYER remove the screws holding the door,pull out on the front panel at the top where it meets the top,then you will see some screws holding brackets securing the top remove these.then remove screws holding front bulkhead.then you will see the blower housing ,while there make sure blower wheel is not loose on the shaft from the recent vibrating Hope this helps......
Sep 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I replace the ac/heater blower moter?
Hope this helps....please don't forget to rate...thank you:
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  3. Disengage the wire harness connectors from the retainer.
  4. Disconnect the blower motor electrical connector.
  5. Remove the motor cooling hose.
  6. Remove the screws and remove the blower motor.
    NOTE
    Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
  7. Remove the wheel from the blower motor as follows:
    • Remove the push clip.
    • Remove the wheel from the blower motor.
Blower motor cooling hose
Blower motor mounting plate
To install:
  1. Install or connect the following:
    • Wheel to the blower motor, if removed.
    • Blower motor and securely tighten the screws.
    • Motor cooling hose
    • Blower motor electrical connector
    • Wire harness retainers
Sep 15, 2010 | 2005 Mercury Grand Marquis
BLOWER WHEEL LOOSE
It's not unusual for this to happen. Especially if the unit is old and has never been "tuned-up" every couple of years. And by tune-up, I mean clean all the dust out of the unit, clean out the exhaust vent and check all moving parts. Take a look at the blower and its mounting hardware. Does anything look worn or damaged? How old is this dryer?
Dec 14, 2009 | Frigidaire Dryers
My coleman 3 ton heat pump blows very little air
Check the blower capacitor and blower speed, you probably have a 3 or 4 speed motor make sure it's on medium high or high speed.
If these are ok then shut the power off to the indoor unit and pull the blower housing out so you can see the blower wheel, make sure it's clean and very carefully spin the wheel to see if it spins freely keep hands away from wheel while it's spinning, if it doesn't then the bearings are bad and you need to replace the motor.
Apr 28, 2009 | Heating & Cooling
Sanyo  Split System Air Conditioner Logo
181 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
