Question about Garden
Change saw How to start it
  • 3,799 Answers
This will depend on the make and model of the chainsaw.
Posted on Apr 28, 2013
  • Deno May 05, 2013
    How to start it
  • Michael Green May 05, 2013
    Hold the safety switch and press "Start" or pull start handle or turn key to start or read the manual.
I have a stihl cutoff saw. Newly purchased. It will start an run for a minute an cut off. Sometimes it will start back an sometimes I have to wait awhile
The vent nipple in the tank is not good open? can also but a thermic problem in the ignition coil is also possible , It is not the first time I do this along with a brand new saw. Go quickly change the saw if, within eight days of purchase entitles you to sit there and not forget your receipt
Oct 01, 2015 | Stihl Saws
Saw starts but revs and then quits
Process of elimination, start with fuel, spray some starting fluid into the air filter if the saw runs longer and then dies you have a fuel problem . Change fuel filter and try to start again, if that does not fix it check carb, may have to disassemble and get a kit, but before you put it in have a saw mechanic look at the needle seat and inspect for pits- the ethanol fuel will pit and the carb is ruined.
Sep 04, 2013 | Husqvarna Garden
14 in. saw with leeson motor
To start with what size circut are you trying to run the saw on? What ever the amperage is on the saw will draw almost 3 Xs the amperage rating of the saw on start up. If the circut is a 20 amp the breaker should hold long enough to start the saw. Also the saw should be the only thing running on the circut at the time. A 1-1/2 hp motor is a good size one aproximately 15.2 amps If you circut breaker is twenty amps and you still pop the breaker you may want to convert the motor to run on 220 volts as that will drop the load to approx. 7.6 amps Youcan run the saw on a 20 amp. 220 volt circut with no problem unless there is a problem with the motor. If the outlet is the only outlet on the circut it is an easy change to convert the circut.
Mar 02, 2013 | Target Portable Masonry Saw PS1411S...
The saw wants to start running but the saw braker pops before full speed run. I am running on a 30 amp outlet and checked all cords. Thank you
If you have access to an ammeter, check the draw when the saw starts. I don't know what the rating of the saw is but I doubt it's more than 30A. If the startup draw is more than 30A the saw may have a short in the starting circuit. If it's less than 30A the breaker may be bad; change the breaker and retry.
Jun 27, 2011 | Target Saws
I have an older model 12 in table saw every once and awhile motor will start t smoke after using only a couple mn.
The motor or the wood piece your try to cut? because if the motor is "smoking" i bet it do it once.So change the saw blade and post back please.
Oct 12, 2010 | Craftsman 10" Table Saw
Blade comes out while sawing
I have used the same tool. Make sure that the blade release/ hold tab is engaged. Maybe the return spring is fouled or stuck. Try some lubricant.
Jun 20, 2009 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Craftsman 42cc chain saw
Hi
First change the plug with a new one with the same heat range.Clean the cilinder wings and the fan housing holes.Check the air and gas filters(clean them).Change the gas from gas tank.Dsassembly,check and clean the carb with compressed air.
Start the engine.
Sep 20, 2008 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
