Question about Echo GT-225 Curved Shaft Trimmer, 21.2cc with i-30 Starter
Runs for short period then stops
Will start then run poorly for very short period then stop. Choke dwill make it run very fast but it still stops.
  • Echo Master
  • 7,482 Answers
Hi abob
Posted on Apr 28, 2013
Water coming out overflow , hot engine
It sounds like the thermostat is stuck closed.
Apr 06, 2014 | 1995 Cadillac Seville STS
I've a 1981 Vette that idles very rough with a cold engine start.
You need to have the choke adjusted so it runs on a fast idle so the engine can warm up or you may need the carb to be rebuild and adjusted properly.
Jan 31, 2014 | 1981 Chevrolet Corvette
Runs but quits
Probably gummed up carb. If you don't want to try to rebuild the carb, then try adding a really good carb / fuel injector cleaner to the gas/oil mixture. don't forget to use a very small amount, then run the motor as fast as it will go for short periods of time to try and dissolve the gumming in the jets.
Aug 28, 2012 | McCulloch Garden
May mac 110 starts then it stops. I choke it it fires then i unchoke it and it starts and stops running.
Try backing the choke off about 1/2 way after it pops, and allow it to run for a few moments on that setting. Once the engine warms up, you can back the choke off completely. My Mac mini has no primer bulb, which means using the choke in a similar manner. Don't forget to set the 'fast idle' button on the throttle before starting (blipping the throttle will release the fast idle button). Hope this helps!
Sep 09, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My Honda X8R scooter starting problem when warm
sound like the engine might be worn out do a compression test
Jul 12, 2009 | 2002 Honda Xr Baja
My yamaha 130hp outboard starts and runs good but
The carbs need to be cleaned.There is a high speed jet in the carb that is more than likely stopped up. Jim OMC retired mech.
Jul 07, 2009 | Boating
Sputtering at low speeds and takeoff
your low speed jets are stopped up ,the carbs need cleaning, go to walmart a buy some SEAFOAM, poor it in your gas tank ,start it up on choke, and when it start ot clear up take it off of choke, or ride it until it clears up. after it starts running good get it synchronized
Mar 27, 2009 | 1986 Honda GL 1200 Interstate Gold Wing
Saw stops when i give it gas.
  • plugged fuel filter
  • cracked/loose fuel line allowing air (instead of fuel) into the carburetor.
  • poorly fitting fuel cap
  • plugged or disconnected/broken pumper line
Feb 16, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Echo GT-225 Curved Shaft Trimmer, 21.2cc with i-30 Starter Logo
267 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
