Question about Garden
Can't loosen nut to change lawn mower blade
I'm trying to replace the blade on my B&D 850 electric lawnmower. I can prevent the blade from moving, but when I attempt to unfasten the nut, the nut just rotates. I think the nut is "frozen" to the threaded shaft. How can i prevent the shaft from rotating?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
You are going to need a impact gun to get it off
Posted on Jun 07, 2014
SOURCE: When trying to remove nut to change blade on my
Try to get on the shaft with a pair of vise grips. Let me know if this does the trick.donnyb60
Posted on Mar 23, 2009
AUTODOC01
  • 216 Answers
SOURCE: Mower Blades
most lawnmower shops can help you prob just a worn keyway ! or goto black&decker.com for closest repair shop?
Posted on Aug 27, 2009
HansPP
  • 2510 Answers
SOURCE: 21.0HP 46 Mower Lawn Tractor
Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
Posted on Apr 02, 2011
  • 601 Answers
SOURCE: I cannot remove the blade
You can use a pipe wrench on the shaft and a regular wrench on the nut. Disconnect your spark plug and tip the mower onto it's left side. You will have to use your left hand to go down through the mower shoot to hold the pipe wrench and your right hand to unbolt the the blade attaching bolt, it should come off immediately.
Remember you may have to purchase a new blade holder, since your problem shouldn't occur if your blade holder was OK. GOOD LUCK.
Posted on Jul 28, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Lawnmower won't start. Was running then just
Hi kkeane20...
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me thumbs up
Posted on Sep 15, 2011
Hi I haven't got a photo as I've just put it away, I tried for over an hour to remove the blade and I just couldn't, its just a standard electric rotary qualcast lawnmower
Holly put some WD40 on the nut and then leave for 1hr. Try by tightening the nut first and it might loosen enough to get the bolt started in the opposite direction. If this dont work find someone with a blow lamp to put some heat to it. Should work
Apr 30, 2016 | Electric Garden
Why won't my Honda HRX217VLA lawn mower start
Hi Duane:
I'd be thinking that it's possible that the alignment key on the flywheel has sheared. That will throw the timing out and it can't run.
Fix is pretty straightforward.
Disconnect and remove pieces until you have the flywheel exposed. Loosen the nut. Lift on the flywheel and smack down on the nut with a plastic mallett to loosen the flywheel. Then remove the nut and flywheel. Replace the key (get replacement ant any lawnmower or chainsaw service shop)
Put it back together and it should run just fine.
Cheers.
Nov 04, 2015 | Honda HRX217VKA Lawnmower
Black & decker MM 850 Electric Lawn mower/mulcher. Upon start up, there is major vibration. No way I can run it like this..
Try removing the blade. If the mower runs smooth, replace or balance it.
If not, the mower shaft may be bent. Did you hit something hard with the blade?
Gary
Aug 11, 2011 | Black & Decker 19" Electric Lawnhog...
I cannot remove the blade from my B&D MM575 mulching mower. The manual says to block the blade, then loosen the nut. However, when I block the blade and turn the nut, the shaft continues to turn,...
Jul 28, 2011 | Black & Decker Black and Decker Mm575 18"...
I have a black and decker lawn hog mower with a 19 inch cut that i am trying to change out the blade. My problem is i cant get the mounting nut off becausethe shaft keeps turning. I have tried everything,...
are you turning nut the right way ! on a lot of mowers, the nut turns off the opposite way the blade turns, to keep it tight. good-day ! Loosen the nut in the center of the blade with a wrench by turning the nut counterclockwise.
Jul 14, 2011 | Black & Decker 19" Electric Lawnhog...
20" lawnmower 3.75HP Model #11A-072A022
Lawn mower blades bolts are reversed thread. Its righty loosen, lefty tighten....
May 07, 2011 | Garden
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Mower Blades
Aug 27, 2009 | Electric Lawn Mower
Blade is loose, turning nut just turns motor.
put a screwdriver in the bottom of the motor that should do it
Jul 26, 2009 | Electric Lawn Mower
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
