Question about Lanier Ld445c Ld435c Ld430c Ld425c Ld420c Newdrum Kit
LD 425c printer not loading toner
Ran out of black toner, replaced with new cartridge. Still showing message to add new toner. Thought is was a faulty cartridge, tried a different one, still have the same issue. "Add Toner" What can I do now?
4 Suggested Answers
  • 158 Answers
SOURCE: I have a lanier lp-138c that is giving me a black
It could be that the black developer unit is clogged. The toner low sensor is located in the black developer unit. A trained copier tech may be needed to troubleshoot this.
Posted on Apr 29, 2009
Testimonial: "great advise worked well but the copier had many more problems...."
santosj27
  • 263 Answers
SOURCE: I have a lanier ld122 copier/fax. It told me to
First of all check if the doors are well closed.
If everything is well closed you can have several problems:
1º Toner supply defective.
2º TD sensor defective
3º Development unit defective.
If you don't have technical training i advise you to call the provider.
Posted on Feb 28, 2011
  • 44 Answers
SOURCE: My copier ran out of toner, I replaced it with a
There may be a clog in the toner supply unit, if you have a small vacuum made for copiers vacuum the toner supply unit and see if it corrects the problem if not you may need a new toner supply unit. Hope this helps
Posted on Jul 17, 2011
An unsupported black toner cartridge is installed
Some replacement cartridges require a new "chip" be installed to tell the printer that the cartridge is a match. I would check with New Egg and see if they forgot to send the chips, if required. I don't know of a manual bypass to the system.
Dave W.
Sep 14, 2012 | Xerox Phaser 6100/DN Laser Printer
We have a Ricoh Aficio 350 copier that is quite old but has worked well through the years until now. It keeps displaying ADD TONER and runnng after we have already put in a new cartridge. Under add toner,...
take the toner supply unit out. toner supply unit is one where toner bottle fits and vacummed clean the unit. the toner unit is blocked. i am a Ricoh technician.
Sep 23, 2010 | Office Equipment & Supplies
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Laser printer problem
For starters aftermarket cartridges are just not like the new ones from Dell. I quit using aftermarket ones long ago to save these headaches, with Dell you can get on Dell Chat and they will gladly help with issues like this. Try that with "Bob's Printer Cartridge and Music Rental" you won't get anywhere.
Mar 13, 2008 | Dell 3100cn Laser Printer
Toner problem
R u using gen OEM toners?
Dec 28, 2007 | Ricoh Aficio AP3800C Laser Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Lanier Ld445c Ld435c Ld430c Ld425c Ld420c Newdrum Kit Logo
109 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
