Question about Pentair SunTouch Single Body Control System - Includes temp sensors (20-FT water, 40-IN air) - (520859)
Air Error Message & Calibrate water temperature
My panel shows that calibrate water temp is 155F/86F. Is it normal? I tried to change the calibrate water temp, but I couldn't. Also, the panel displays "Air Error" message, and I was not able to change or get rid of the error message. Please advise me.
    Top Expert:
  • Pentair Master
  • 5,075 Answers
Replace temp sensor
Posted on Oct 07, 2017
  • 61 Answers
SOURCE: Pool heater will not heat
Im no pro, but I know there is an air sensor behind the main board. If the fan is running you probably have a problem with that sensor. If your lucky the air hose could have just popped off.
Posted on Apr 04, 2009
Muzzi_123
  • 749 Answers
SOURCE: Minimaxpower on but fails to start no error code just flashes off
hi, it seems like a component malfunction, Try a hard reset Just unplug the power cord for 30 minutes or more, then try again.
Posted on May 07, 2009
  • 139 Answers
SOURCE: I have a MiniMax NT Heater and when turning it on, EO 5 message
ign failure code, replace ignitor
Posted on Jun 20, 2009
  • 246 Answers
SOURCE: The Digital Panel on the front of my Pentair
TIME TO CLEAN THE FILTER
Posted on Nov 18, 2009
heatman101
  • 43501 Answers
SOURCE: I have a pentair easy
I believe you will find that the sensor its self is bad....
Pull it out and remove the wires going to the board... attach an ohm meter to the wires..if it reads nothing or zero you know for sure it is bad... if it is reading a resistance then it should change say if you grab it and hold it in your hand...if not then it is bad.... if the sensor seems to be working then the board is bad...
heatman101
Posted on Feb 13, 2011
Calibrating Honeywell CT3600
In the thermostats setup there can be a calibration mode however this is a chasing the gragon type of endeavour that rarely ever culminates in thermostats jiving with another, they typically are off plus or minus 3-4 degrees anyways as they are not designed to maintain too narrow of a temperature differential or the furnace will short cycle or run too often & stop in short order.
Jun 29, 2013 | Heating & Cooling
You have to calibrate the touchscreen with your stylus
the message shows the problem, do calibrate your mobile the msg will automatically gone.
Nov 18, 2011 | Cell Phones
How to install ac mode actuator on 2003 gmc sierra
prev.gif next.gif Air Door Actuators Removal & Installation Air Temperature Actuator Air Temperature Actuator Replacement gm-10-00-559.gif
To Remove:
CAUTION
Do not apply power to the actuator when it is removed from the HVAC module.
  1. Remove the instrument panel hush panel.
  2. Disconnect the connector from the air temperature actuator.
  3. Remove the air temperature actuator mounting screws.
  4. Remove the actuator from the HVAC assembly.
To Install:
  1. Position the air temperature actuator on the HVAC assembly.
  2. Install the actuator mounting screws.
  3. Install the electrical connect to the air temperature actuator.
  4. Install the instrument panel hush panel.
Right Side Air Temperature Actuator (2003-2007) Right Air Temperature Actuator Replacement gm-10-00-560.gif
To Remove:
CAUTION
  1. Remove the instrument panel carrier.
  2. Disconnect the connector from the right air temperature actuator.
  3. Remove the actuator mounting screws.
  4. Remove the right air temperature actuator.
To Install:
  1. Position the right air temperature actuator on the HVAC assembly.
  3. Connect the electrical connector to the actuator.
  4. Install the I/P carrier.
  5. Calibrate the actuator.
Left Side Air Temperature Actuator (2003-2007) Left Air Temperature Actuator Replacement gm-10-00-561.gif
To Remove:
CAUTION
  1. Remove the I/P insulator panel.
  2. Disconnect the connector from the left air temperature actuator.
  4. Remove the left air temperature actuator.
To Install:
  1. Position the left air temperature actuator on the HVAC assembly.
  4. Install the I/P insulator panel.
To Remove:
CAUTION
  1. Remove the floor air outlet from the floor duct.
  2. Remove the center console and center console duct (if equipped).
  3. Disconnect the electrical connection at the mode actuator.
  4. Remove the mode actuator mounting screws from the HVAC module.
  5. Remove the mode actuator with the actuator cam attached.
To Install:
  1. Position the mode actuator with the actuator cam to the HVAC module.
    • Align the heater/defroster valve lever with the cam slot
    • Align the A/C valve lever with the cam
  2. Install the mode actuator mounting screws.
  3. Connect the mode actuator electrical connection.
  4. Install the center console duct and the center console (if equipped).
  5. Install the floor air outlet duct extension to the floor air duct.
  6. Calibrate the actuator.
Air Inlet Actuator/Recirculation Actuator Delphi Recirculation Actuator Replacement (Delphi) gm-10-00-564.gif
To Remove:
CAUTION
  1. Remove the instrument panel upper trim panel.
  2. Remove the instrument panel lower trim panel and glove box assembly.
  3. Remove the passenger side air bag.
  4. Disconnect the connector from the recirculation actuator.
  5. Remove the recirculation actuator mounting screws.
  6. Remove the recirculation actuator from the HVAC assembly.
To Install:
  1. Position the recirculation actuator on the HVAC assembly.
  2. Install the recirculation actuator mounting screws.
  3. Connect the electrical connector to the recirculation actuator.
  4. Install the passenger side air bag.
  5. Install the instrument panel lower trim panel and the glove box assembly.
  6. Install the instrument panel upper trim panel.
  7. Calibrate the actuator.
To Remove:
CAUTION
  1. Remove the HVAC module assembly.
  2. Remove the evaporator core cover from the HVAC module.
  3. Remove the recirculation actuator from the HVAC module assembly.
To Install:
  3. Install the evaporator core cover to the HVAC module.
  4. Install the HVAC module assembly.
Jul 09, 2010 | 2000 GMC New Sierra 1500
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
THS error
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
Jun 17, 2008 | TallyGenicom 2280 Matrix Printer
THS Error on warrantee printer tally serial printer
Apr 09, 2008 | Tally Matrix T2280 Printer
Oven temperature
Press and hold the bake button for 5 seconds, will go to calibrate mode, press the up or down temp to adjust yiour oven + or - 30'
Mar 07, 2008 | Whirlpool SF378LEPS Stainless Steel Gas...
Pentair SunTouch Single Body Control System - Includes temp sensors (20-FT water, 40-IN air) - (520859) Logo
214 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
