Question about Panasonic Kenmore Canister Vacuum Vacuum
Replace retractable power cord kenmore 26312606
360 manual
With all that's involved in replacing the cord and potential cord reel damage, it's more cost effective to just have the entire cord reel, complete with new cord, replaced. Less time consuming thus less costly to you. Hope it helps!
May 26, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Kenmore 116.26212602 cord won't retract completely
This is a common Kenmore problem. The cord may have kinked inside the cord reel, You can remove the top by taking the screws out some are hidden under the switch. If the cord gets too close to the edge of the reel it can bind. Do be careful as the spring in the cord reel can jump out and it hurts. I would take it to a dealer.
Jan 31, 2014 | Vacuums
The power cord does not retract or rewind when the button is pushed. How can I repair this?
Sometimes you can help get the springs working again, by gently pulling the cord out a little further and then let it slowly in while pushing the cord retract button.
Nov 08, 2012 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister vacuum retractable cord jammed
go and buy it from www. repairclinic.com
God bless you
Jul 06, 2012 | Vacuums
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Feb 12, 2011 | Vacuums
My kenmore progressive caniser needs a new power cord. the plug had one of the metal prongs break on the plug. how can I replace the cord? model 22812201
I do not know if you want to replace the replace the power cord or the receptacle for the power wand?
If you need the prong for the power cord you can purchase a replacement power plug from a local hardware store and it will function and look reasonable. If you want it to look like the original factory plug you can purchase the plug from the following link for $29.56 plus shipping.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=4370695&productGroupId=0020&supplierId=116&mv=rr
You could also purchase the cord and retractable reel if you want to make it easier for $53.38 plus shipping by clicking on the following link.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=8192087&productGroupId=0020&supplierId=116&mv=rr
Clicking on the links below will show the exploded parts view so you can see how to disassemble the unit to replace the cord.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0303013-00003.png
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0303013-00001.png
If you need the power wand plug click on the bellow link for $21.99 plus shipping.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=8175251&productGroupId=0020&supplierId=116&mv=rr
I hope this helps and is the information you needed.
Jun 22, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Panasonic Kenmore Canister Vacuum Vacuum Logo
24 people viewed this question
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
