Question about LG 47LH40 47 in. LCD HDTV
Lg 47lh40 The left half of the screen is white,, but the right half works just fine. Maybe its a left side driver issue? I have no idea. Please help
  • 1 more comment
  • Joseph Raynes Apr 28, 2013
    I found a service diagramhttp://www.searspartsdirect.com/partsdir...
    BTW, I got this tv off craigslist free section. the guy didn't know what was wrong with it, nor did he want to spend money on fixing it. Pretty nice find, I'd say
    Follow up-I called LG, and they were no help. They offered a service person to come out for a minimum of $90. Thats just for a diagnostic. So I opened the back, and low and behold, the cable running from the main board to the LCD was disconnected. The solution-plugged it back in, and now I have a full working screen. Thanks.
    Top Expert:
  • LG Master
  • 75,304 Answers
Check its connection between LCD pane and T'con board for any loose contact.
Posted on Apr 29, 2013
LG model 55uf6450. TV turns off and get static with left half a side of magenta. Audio is white noise. What is wrong?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 01, 2017 | LG Televison & Video
I have an LG 50LN5600-UI. The left half of my screen is now darker than the right any idea what the problem maybe?
It could be that the lamp is burned out on that side. Close up-, Shine a flashlight into it and if you see an image form it's simply the lamp. If not, then it could be a processor issue or something more complicated.
Jul 11, 2016 | LG Televison & Video
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
My LG LH40 47Inch screen shows logo then gos off
Main board fault. Contact any service technician, or the authorized service center for LG. The second said will be the best.
Gopakumar Gopalan Google
Apr 01, 2014 | LG 47LH40 47 in. LCD HDTV
Half the screen is white, half the screen is colorful
I would try using an external display. That will prove the GPU. If it is OK then the display is faulty, if not the GPU is faulty.
Nov 20, 2013 | ASUS Eee Computers & Internet
Left half of screen dimmer than right
same issue with my 47le5900 - I have fixed it... if I look through the back panel I can see a circuit board on the right... coming out of this at the top are two flat data cables, each about 1 1/2 inches wide, one is labeled (L) the other (R), it seems the (R) one was a little loose, so I pressed it downwards with a small screwdriver, problem solved.
Jun 25, 2012 | LG 42LE5500 42 in. TV
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
42lh3000 Right half of screen is black but goes better when warms up, still flickers at times, how can i repair this? The tv is about 2 years old and never had a problem with it before, the sound is great...
I have fixed an LG 42LH3000 with this very problem. Large TVs have a tendency to flex and bend ever so slightly when being moved or through heat, this can affect the connection of the ribbon cables at the top of the screen - either at the end where the Tcon board is or where the screen driver board is. When one end of the cable loses contact, half the picture goes (there are two ribbon cables. one for each side of the screen).
Remove the cables then carefully reattach them. If you still have an intermittent problem would suggest leaving the screws out of the T-con board as this will give the ribbon cable more slack.
Don't attempt any of this unless you know what you're doing - risk of damage to screen if handled indelicately also risk of fire when plugged back if the ribbon cables aren't secured properly.
Dec 19, 2011 | LG 42LH3000 42" HDTV LCD TV
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
Grandson dropped his Acer Aspire One. Now has double screen with blank white screen in center. (Left half of a normal screen shows on left side of screen and on right side of screen, with white screen in...
My suggestion is to replace the LCD with new one. Let the certified technician to work on that. You cannot perform the DIY on that. Its too complicated.
Aug 18, 2010 | Acer Aspire One PC Notebook
LG 47LH40 47 in. LCD HDTV Logo
151 people viewed this question
Computer Repairing
Computer Repairing
