Question about KitchenAid KFIS27CXMS Bottom Freezer Refrigerator
Kichenaid model KFIS27cxms2
Water freezing at bottom of feezer
Kichenaid french door fix freezing water but still doing it
Go to your local appliance dealer and ask for the drain repair kit for your model, it runs about 20 bucks and will fix this issue. You will need to get behind the unit and change it but it comes with instruction as well and takes mins to change.
Good Luck
Jul 24, 2014 | Refrigerators
Feezer shut down with hi-temp alarm
Sounds like a defrost problem. Water came from frozen evaporator that thawed after being unplugged. It will operate great until evaporator freezes over again because it's not defrosting. Defrost components are defrost timer or Board, defrost heater, and defrost thermostat. One or more of those components have most likely failed. Also be sure Freezer / evaporator fan is working.
Aug 29, 2017 | Refrigerators
We have a stainless model # pfss5nfxbss. With the feezer on the bottom.. freezer is cold but the refridge. not cooling?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 20, 2010 | GE Refrigerators
Hi, I have a 3 yr old Haier Fridge serial #HBP18GAAWW, the feezer is on the bottom. The food and drinks keep freezing in the fridge and there is alot of frost in the freezer. Is there a problem with his...
Have you tried to lower the temp.settings?? If settings are about 1/3 of the range, then it could be a thermostat problem.
Keep me posted!! Rate this post!!
Aug 12, 2010 | Haier Refrigerators
The freezer freezes up and no air circulates to the refrigerator. The Fan motor is working.
is there frost on the inside back wall in the feezer you have a defrost problem. a bad door gasket will cause the duct from the freezer to fridge to fill with frost so the air cant get to the frige
Dec 25, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Slimline feezer 8504 126 15011 works intermittantly
why do you need a freezer if you only have ice
Nov 07, 2009 | Washing Machines
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water leaking from feezer
sounds like a faulty defrost system or a blocked/iced drain or both. live chat me for a step by step solution cheers
Mar 26, 2009 | Refrigerators
Kichenaid refrig not keeping cold
Need to have someone with multimeter check the compressor and the capacitor. May be the start capacitor not allowing the compressor to run or continue running. Let me know, Sea Breeze
Mar 19, 2009 | KitchenAid Refrigerators
KitchenAid KFIS27CXMS Bottom Freezer Refrigerator Logo
55 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
