Question about Acme 00930T Toledo Hardwood Double Pedestal Formal Dining Table
Why will my double pedestal table not close properly when I do Not have the leafs in
I find this a total mystery, when I put 1 and even 2 leafs in the table closes perfectly. Without the leafs there is a gap. Can you shed light on this situation.
    Problem Solver:
  • 10 Answers
Are their dowel holes that line up the leafs?
Posted on Jun 28, 2013
Testimonial: "Yes there are dowel holes. We tracked down some new levelers and bought a set of locks. It is now OK. Thanks for your help. Appreciated."
Put the staff extensions in a seperate greeting but able to make it play at all times by pushing a button for example "You have reached......... " and at the end "for a list of the staff extensions pr
You need CCR which is more complex.
AA
AA/Grtg/Grtg/1 = Thank you for calling ABC
AA/Grtg/Grtg/2 = Thank you for calling ABC we are now closed
AA/Table/1/Morn = Grtg 1
AA/Table/1/After = Grtg 1
AA/Table/1/Even = Grtg 2
CCR
CCR Path 0 = If you know your parties ext plz enter it now
for list of staff press 1
PATH 1 = MENU, record list of Staff
You need to disable the CCR Tree in Table before you can make changes. DISABLE to disable or 1 to enable.
You should get a tech in to do this and train you how. 1 hour should do it.
Dec 15, 2014 | Nortel Networks Business Series Terminal...
One end of the table when expanded sags ?
Did you find a solution, mine has done the same?
May 29, 2014 | Calligaris Hyper XR Extendable Dining...
Weatherworks pedestal fan
ok well we cant help either
Sep 20, 2013 | Garden
We have a very small dining room space, but would still like to put a dining room table and chair set there. Can anyone suggest the best way to furnish a small space like this?
The best dining room table shape for a room with limited space is a round table. You should look into finding one with an extension leaf if you have enough space to open it. Try looking for a table where you can fit more people around it by purchasing one with a pedestal base. This leaves more room for your guests legs without the legs of the table getting in the way.
Aug 09, 2012 | Furniture
What is the best way to set up a buffet table?
The first rule in setting up a buffet table is to makesure that it can be accessed by people from at least 2 sides. Cover the table with a table cloth. Lay out the foot at different heights (raisedpie pedestals can save space and be really aesthetically pleasing!) You'll wantto put flatware at one end and plates at the other end. Voila! You have a buffet table!
May 29, 2012 | Furniture
How do I rename a tax table on my Casio PCR-T2000? I am interested in changing all my registers to the Ontario HST of 13%. Thanks very much.
Use the PGM key and set to PGM. 3, sub total, enter tax table {1, 2, 3, 4}, Tax PGM, 13.00, ca/amt tend, skip to set 'round off/add-on', ca/amt tend, sub total. 4 tax tables are used for the following purposes: table 1 for the federal tax items, table 2 for the provincial tax, 3 and 4 for provincial and different tax table.
Jun 20, 2011 | Casio PCR-T2100 BLACK DELUXE 96-DEPARTMENT...
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
Dish washer has a sulper smell when turned on.
Without seeing it and assuming the dishwasher is functioning properly, the drain hose from the dishwasher to the sink drain might have a kink in it from when the put in the new sink.
You should be able to visually look at this under your sink.
Good luck
Get back to me if you need more assistance
Kurt
Mar 19, 2009 | Plumb Pak Continuous Waste Center Outlet,...
Casio Register 265P - Doubling Tax in Sales Total
Hi.
That could be tricky. we will need to go through the tax setup in your machine.
My first questions are:
1. Does it happen on all department (item buttons)?
2. Does it happen no matter what payment method you use (cash, check,credit)?
3. When you push Subtotal, does it show the wrong amount then, or only when you press a payment type to open the drawer?
Mark
Nov 12, 2008 | Casio Parts Cash Register PC Desktop
Acme 00930T Toledo Hardwood Double Pedestal Formal Dining Table Logo
220 people viewed this question
Top Acme Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Acme Furniture Expert? Answer questions, earn points and help others
