Question about Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner
Cd clamping error - Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner
T14-115 error
Clamp error.. (clamping mech for the master)
press <all reset> key.
Make sure that the solenoid for the clamping action is not actuated.. that is .the clamp is not open.. Open the top cover to check.
Feb 26, 2013 | Office Equipment & Supplies
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
I have nad c541i,for last few days,it not reading the cd,as the disc goes in,there's a bit sound from the spindle which goes off after 5 secs,but doesn't read the disc,the screen keeps flashing like --...
this has the sony mechanism so if you take the lid off and unscrew the 2 screws, 1 at either end of the cd clamp and remove it, you should see part of a large cog just under the front of the cd tray, try turn this clockwise and the tray should open.
once open, you should be able to see a small plastic cover, loosen this slightly and replace the belt as this is prone to slipping on this mechanism stopping it clamping the disc properly when closed.
the sound you say is the spindle motor, is actually the loading motor trying to lift the whole laser mechanism up towards the puck to clamp the disc as there is not enough tension left in the belt.
help it along by hand and you'll see what i mean.
hope this helps?
Nov 21, 2009 | NAD C521 CD Player
Hiya, I have a NSM The Performer wall. When I make a selection it goes to select disk but doesnt make a selection but gives error code 73. Having looked at the machine I've noticed at the back of the cd...
Hi Mark,
Go to the nsm website for the list of distributors and products etc, you should be able to order the parts from distribution.
www.nsmmusic.com
Regards
Alan Hood
ami-man
UK
Jul 18, 2009 | Wurlitzer Jukebox CD Player
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
Riso gr 3750 error T14
Means a clamp error. Inspect the clamp on the drum to make sure it moves smoothly and that that clamping mechanism in the back of the machine works as well.
Apr 06, 2009 | Canon PC-140 Black and White Copier
Ps2 error
See if you can play an Audio CD. if you cannot then your Laser CD reading circuit is out of adjustment. Clean the lens and try and if that doesnt work, Add refridgerator magnet to the white clamp that hold the Disc on the Drive spindle. Use a Maghifying glas to get a close look at your Laser lens, and clean off any lint or smudges.
Jan 05, 2008 | Sony PlayStation 2 (PS2) Console
Denon m50
You can probably fix it yourself but you may need some parts. Here's Denon's link that'll take you to the next step http://www.usa.denon.com/
Nov 24, 2006 | Denon D-M50S CD Shelf System
Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner Logo
22 people viewed this question
Top Rimage Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Gareth Cockram
Gareth Cockram
David Steeves
David Steeves
Level 1 Expert
Are you a Rimage Computer and Internet Expert? Answer questions, earn points and help others
