Question about Dryers
DLL 2650BCLAD HOT POINT will not heat.
  • Dryers Master
  • 7,482 Answers
Hi Lynda
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the heating element/thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Bud
Posted on Apr 28, 2013
Tip
Staying in hot water
With water rates on the rise, it is costly letting water run at a remote hot water faucet. It makes more sense than ever to insulate exposed hot water pipes in the basement with the foam insulation that's split lengthwise.
As an added benefit, freezing pipes can be avoided during power outages. The hot water pipes freeze sooner than the cold water ones because the freezing point of heated water is closer to 32*F than the freezing point of cold water. Cold water has a depressed freezing point due to dissolved minerals from municipal water treatments. Water that's been heated has fewer contaminants, hence less freezing point depression!
on Feb 28, 2010 | Washing Machines
Kernell32.dll error on photoshop cs6
hi,
i downloaded Photoshop cs6 trial and when i click the Photoshop icon to open the software i get a window:
Photoshop.exe - Entry Point Not found
The procedure entry point GetLogicalProcessorInformation could not be located in the dynamic link library KERENEL.32.dll.
What can I do???
I have allready tried to reinstall....
still the same.....
HELP
Dec 16, 2012 | Adobe Photoshop CS6 Extended 65170137
Clkern.dll was loaded,but the dll register server entry point was not found.this file can not be registered
http://www.fix-all-dll-errors.com/clkern.dll/
Once you go to the above link click "Fix dll errors now" button,
it will register the dll file for you.
Dec 29, 2010 | Car Audio & Video
Error in ms office
Rename and Reinstall the Vbe6.dll File
NOTE: You need your Office CD-ROM to complete this task.
  1. Quit all currently open programs.
  2. Start an MS-DOS prompt in a window by doing one of the following:
    • Microsoft Windows 95 or Windows 98: Click Start, point to Programs, and then click MS-DOS Prompt.
    • Microsoft Windows Millennium Edition (Me): Click Start, point to Programs, point to Accessories, and then click MS-DOS Prompt.
    • Microsoft Windows NT 4.0: Click Start, point to Programs, and then click Command Prompt.
    • Microsoft Windows 2000 or Microsoft Windows XP: Click Start, point to Programs, point to Accessories, and then click Command Prompt.
  3. To change the directory to the location of the Vbe6.dll file, type one of the following (including the quotation marks), and then press ENTER: CD "C:\Program Files\Common Files\Microsoft Shared\Vba\Vba6"-or- CD progra~1\Common~1\Micros~1\Vba\Vba6NOTE: This is the default directory for the Vbe6.dll file. If you installed Microsoft Office into another drive or directory, you must type its path.
  4. To unregister the Vbe6.dll file, type the following.
    In Windows 95, Windows 98, or Windows Me, type: C:\Windows\System\REGSVR32 /U VBE6.DLLIn Windows NT 4.0, Windows 2000, or Windows XP, type: REGSVR32 /U VBE6.DLL-or- C:\Winnt\System32\REGSVR32 /U VBE6.DLLNOTE: This is the default directory for the Windows System directory. If you installed Windows into another directory, you must type its path.
  5. In the MS-DOS prompt window, rename Vbe.dll to Vbe.old by typing the following and then pressing ENTER: rename vbe6.dll vbe6.old
  6. Quit the MS-DOS prompt window. To do this, do one of the following:
    • Type Exit at the command prompt, and then press ENTER. -or-
    • Click Close (the X in the upper-right corner of the window).
  7. Start Microsoft Word.
  8. On the Tools menu, point to Macro, and then click Macros.
    The Windows Installer detects that the Vbe6.dll file is missing on the system, installs the file from the Office CD, and registers it again.
Mar 23, 2010 | Microsoft Office Professional 2007 Full...
Blocked out my laptop!
Do the following to restore it.
1. Go to Start Menu
2.Click on Run
3.Enter the following %SystemRoot%\system32\restore\rstrui.exe
4.Click Ok
5.Click on the Welcome to System Restore page that you will see
6. Create a restore point
7. Click Next
8. Give a name to your restore point
9. Click on Create
10.Close after the restore point has been created.
Note: If the system restore point is turned off, clear the check box in the system properties dialog box and click ok after you are done.
Regards
Sep 24, 2009 | Computers & Internet
Won't boot/reboot after turning off yesterday
1. boot from a Windows CD and go for the repair option.
2. Copy usp10.dll from c:\windows\servicepackfiles\i386\gdi32.dll to c:\windows\system32\usp10.dll. (Do keep a backup copy of the old usp10.dll in c:\windows\system32 directory )
3. Reboot normally
http://www.aa1consulting.com
Jul 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
to produce entry point _except_handler4_common could not be located in the dynamic link library msvcrt.dill
Apr 19, 2009 | Microsoft Windows XP Professional
Unable to log on to computer
BRING IT INTO BEST BUY SO THEY CAN RUN A DIAG ON IT, YOU MIGHT HAVE BAD HARDWARE, OR THE DISK YOU MADE WAS BAD.
Jun 11, 2008 | Computers & Internet
My laptop was turned of during an recovery point[system restore]
Try doing a system restore from a previous retore point. However, you will not be able to recover any files that were saved after that point.
If all else fails, you may have to reinstall the OS. The "wininet.dll" file may be from some software you installed at a later point..
May 15, 2008 | Computers & Internet
Dryers Logo
29 people viewed this question
Top Dryers Experts
